Engine detailing question
Old Sep 19, 2002 | 06:19 PM
gmcclurg's Avatar
gmcclurg
Default Engine detailing question
Has anyone found a good way to clean up or repaint the plated items such as the Heat Riser, EGR and Brake Booster?
Old Sep 19, 2002 | 06:23 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Engine detailing question (gmcclurg)
If you are talking about the gold cadium plating, then these posts will help you out. http://forums.corvetteforum.com/zerothread?id=390906
Old Sep 19, 2002 | 07:34 PM
78Vette-SA's Avatar
78Vette-SA
I cheated and used Eastwood's Gold Carb Renew. Not NCRS, but looks good to me.
Old Sep 19, 2002 | 08:00 PM
vettfixr's Avatar
vettfixr
I painted the heat riser, intake manifold and master cylinder "Spray Gray" and used Satin Black on the booster. The water pump, fan and brackets are done in "Detail Gray" The paints are from Eastwood and have held up very well. The picture you see shows the engine after about 3 years in the car.
This is what it looks like.
[Modified by vettfixr, 7:05 PM 9/19/2002]
[Modified by vettfixr, 7:42 AM 9/20/2002]
Old Sep 20, 2002 | 02:25 AM
SizzleChest's Avatar
SizzleChest
Default Re: Engine detailing question (78Vette-SA)
BEAUTIFUL!
Old Sep 20, 2002 | 02:34 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: Engine detailing question (SizzleChest)
[QUOTEBEAUTIFUL![/QUOTE]
Thanks!
Old Sep 20, 2002 | 08:35 PM
Disco_Mike's Avatar
Disco_Mike
did you pull the power brake booster to paint?
Old Sep 20, 2002 | 08:47 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: Engine detailing question (Got79Fever)
If you mean me, no. I was able to get most of it from above and then climbed underneath and got what I could. It's not perfect, but what you can see from above looks pretty good.
More pics at:
http://home.hvc.rr.com/joesvette/engine.htm
Old Sep 20, 2002 | 09:56 PM
GTR1999's Avatar
GTR1999
Joe,
Does the carb gold paint dry to a hard surface? I was thinking of that for the headlight vacuum cans. I used POR15 metal mask and that chipped off very easily.
Thanks,
Gary
Old Sep 20, 2002 | 11:54 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: Engine detailing question (gtr1999)
Joe,
Thanks,
Gary
Hard as a rock. I did mine almost 3 years ago and they look the same today.
Old Sep 21, 2002 | 12:30 AM
GTR1999's Avatar
GTR1999
Thanks Joe,
Gary
To Engine detailing question
