What Posi case can I use....
Old Dec 21, 2016 | 03:02 PM
Redvette_22's Avatar
Redvette_22
Default What Posi case can I use....
I have a 72 Vette with a 3.08 posi rear and want to put in 3.70's. Will I have to change the case or can I install a 3.70 ratio on the 3.08 case??
Old Dec 21, 2016 | 03:29 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Yes. You are good to go!
Tom
Old Dec 21, 2016 | 03:44 PM
Redvette_22
Tom
Tom, so the 3.70 R&P will bolt up without a ring gear spacer or need of a different carrier?
Old Dec 21, 2016 | 03:48 PM
Sky65's Avatar
Sky65
The 3.70 will bolt right in. It is only when you go to 4.11 or bigger that you need a different posi unit.
Tom
Old Dec 21, 2016 | 08:26 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Or a thick ring gear.
To What Posi case can I use....
