fiber optics help
Old Sep 20, 2002 | 12:55 AM
telk's Avatar
telk
Default fiber optics help
Is there any place that sells fiber optic wire? I know they sell patch kits. but can 4 or 5 foot pieces be purchased anywhere? Also I read some time ago that monofilament fishing line can be used with pretty good results. is that true or false ? What size or test would be used? Thanks.
Old Sep 20, 2002 | 01:02 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: fiber optics help (telk)
Mono fishing line will work (sort of) but it is very brand specific and it doesn't transmit 10% of the light that real glass does. I spent a long afternoon threading it thru plastic tubing and hooking it up only to be really disappointed with the results.
I found an alternative source of fiber optic cable at Lowe's home improvement stores. There are some outdoor lighting systems that use fiber optics to put out light. I found that they sell it in 25' and 50' rolls. It isn't cheap at about $1.00 a foot. Rather than spend the money on it I've decided just to buy a reproduction rear harness to replace mine with. I've seen the complete rear fiber optic cables for around $90.00.
T
Old Sep 20, 2002 | 06:23 AM
Larry B.'s Avatar
Larry B.
there are a few places that sell it by the foot. I used to have a site saved in my computer but lost it when I reformatted. try an on-line search. it was a street rod parts supplier.
Old Sep 20, 2002 | 09:55 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: fiber optics help (silvervetteman)
I want to send this back to the top. This topic means alot to us guys with the fiber optic lights that dont work correctly. My rears are cut somewhere between the brake lights and the console. I know everything is good at the console and at the light so.
This was just going to be one of those things I just let go. I may have to go to the Home Depot and look this fiber stuff up and get me a 25 ft roll, unless someone comes up with an online place to get it.
To fiber optics help
