Head gaskets for Aluminum heads
Old Sep 20, 2002 | 01:59 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Head gaskets for Aluminum heads
I'm getting ready to order a bunch of goodies which include Edelbrock RPM heads. I'd like to improve on the quench dimension (head to piston) and am curious....are these gaskets ok to use on a daily driver? I asked Edelbrock and they're noncommittal.
0.015" Shim for Iron or Aluminum Heads
Price: $19.50
Part # FEL1094
Material: Embossed Shim with Precision Rubber Coating
Gasket Bore: 4.100"
Thickness: 0.015"
Gasket Volume: 3.2cc
For use in some sportsman drag racing and flat top piston oval track classes. Can not be used on 400ci engines. Embossed shim with precision coating does not cause any brinneling on aluminum heads. 1 gasket per package!
Old Sep 20, 2002 | 02:05 AM
LT1driver's Avatar
LT1driver
Default Re: Head gaskets for Aluminum heads (AlwaysWave)
what made you chose edelbrock over other brands like chevy alum, also are they oval or rectangle port. :cheers:
Old Sep 20, 2002 | 02:08 AM
AlwaysWave's Avatar
AlwaysWave
Default Re: Head gaskets for Aluminum heads (LT1driver)
I'm liking the Edelbrocks because of the flow numbers and their new heart shaped chamber for better combustion, and D shaped exhaust port. The intakes are rectangular port.
Old Sep 20, 2002 | 08:15 AM
rocky1's Avatar
rocky1
Felpro makes good stuff. If they say that they are good for aluminum heads, I'd give em a try.
Got Trick-Flows myself. Love 'em!
Rocky
Old Sep 20, 2002 | 09:26 AM
Matt Gruber's Avatar
Matt Gruber
i would block sand the heads first
Old Sep 20, 2002 | 10:31 AM
AlwaysWave's Avatar
AlwaysWave
Default Re: Head gaskets for Aluminum heads (Matt Gruber)
Ok.....why? What does that do?
Old Sep 20, 2002 | 11:04 AM
Matt Gruber
the key to a good seal with a shim gasket is a smooth surface :cheers:
Old Sep 20, 2002 | 01:38 PM
gkull's Avatar
gkull
How far down in the hole is your piston at TDC? You have to look at piston rock in the bore and minmum quench height. :smash: Piston and head collision is a bad thing! :seeya
Old Sep 20, 2002 | 11:19 PM
AlwaysWave's Avatar
AlwaysWave
Default Re: Head gaskets for Aluminum heads (gkull)
I had a new base model 350 crate motor installed last June. Specs from the Scroggin-Dickey site below. I'm assuming right now that the quench dimension is huge. That's why I'm making preperations for it. If wrong about it, then a conventional 031 or 041 gasket will go on.
1969-85 GM Vehicles 350 Engine
Price: $1,479.95
Part # 10067353
New/Reman.: New
Core Value: $100.00
Transmission: A/S
Cubic inches: 350
Liters: 5.7
All new components assembled into a NEW 4 – bolt main block. Not Remanufactured / Not Rebuilt! An all-new 350 Chevy engine backed by the best warranty in the USA!
Engine Name: 350 LM1
Horsepower: 249 HP @ 5,000 RPM RPM
Torque: 304 Ft/Lbs @ 3,500 RPM
Compression Ratio: 8.50 to 1
Block: 4 – Bolt, 2 Piece Rear Seal, 4.000” Bore
Crankshaft: Cast Nodular 3.480” Stroke
Heads: Cast Iron, 72cc
Valves: 1.940” / 1.600”
Camshaft lift: 0.390” / 0.410” Hydraulic
Duration @ 0.050”: 195° / 202°
Intake: Not Included
This engine can also be used in 1986 model pick-ups. The flexplate (flywheel) must also be changed. Use flexplate #471598.
To Head gaskets for Aluminum heads
