What is this thing?
Old Sep 20, 2002 | 11:32 AM
Jack71's Avatar
Jack71
Default What is this thing?
What is this thing? The wires have been spliced for 30 years, its a mess. Shouldn't it attach somewhere???
Old Sep 20, 2002 | 11:38 AM
Martin72's Avatar
Martin72
Default Re: What is this thing? (74jack)
Are you talking about the white inline fuse holder that you are holding? :confused:
Old Sep 20, 2002 | 11:39 AM
page62's Avatar
page62
It's a fuse holder. But you'll have to trace the wires back to see what it's connected to...
Old Sep 20, 2002 | 11:42 AM
Fevre's Avatar
Fevre
Default Re: What is this thing? (page62)
Someone may have replaced a fuseable link with it. Do you have any wires with what looks like a piece of rubber/foam about an inch long on it? Those are fuseable links and I have 3 in the general area of your picture. That is about all I know about em.
Old Sep 20, 2002 | 11:43 AM
73 LS-4's Avatar
73 LS-4
That wire on mine goes to the relay on the drivers fenderwell, probably about at where your wrist would be in the pic.
:cheers:
Pat Kunz
Old Sep 20, 2002 | 11:44 AM
no_radio's Avatar
no_radio
Looks like somebody spliced in a fuse to the hot lead from your alternator. Does it terminate on the terminal on the back of the alternator? It looks like it in the picture. What may have happened is the fusible link blew at some point in the past, and they replaced it with a fused splice. Probably not hurting anything, although if not properly connected (and it looks like a poor connection) it could lead to things like flickering or dim lights, low voltage, etc.
I think if you trace it back it will go from the positive starter terminal to the alternator post.
Jeff
Old Sep 20, 2002 | 01:36 PM
Jack71's Avatar
Jack71
Default Re: What is this thing? (no_radio)
Sorry, I talking about the thing underneath the fuse holder...
Old Sep 20, 2002 | 03:52 PM
FINWOLF's Avatar
FINWOLF
That would be your finger sorry just had to say that. :lol: :lol: ya I know you don't need a wise guy here
Old Sep 20, 2002 | 03:57 PM
Fevre's Avatar
Fevre
What is on the end of it behind your fingers?
Looks like bubba has been doing some rewiring under your hood. Of course I am wearing the bubba hat now until I settle on an engine and transmission. Why do it right when you can bubbuize it? :jester
Old Sep 20, 2002 | 05:22 PM
verskel's Avatar
verskel
It looks like a "horn" relay which should be attached to the fender well..... :)
Old Sep 20, 2002 | 06:01 PM
Myeye2sky's Avatar
Myeye2sky
Default Re: What is this thing? (verskel)
Yeah. That's the horn relay.
Old Sep 20, 2002 | 06:08 PM
lbell101's Avatar
lbell101
Default Re: What is this thing? (Myeye2sky)
Yep, horn relay.
Mounts to the inner fender well under the fender where it turns under. Just forward of the vacuum tank. It's held on by one bolt (or stud) .
Edit: Oh and... I think the fuse holder is just the hi speed blower wire.
[Modified by lbell101, 5:10 PM 9/20/2002]
Old Sep 20, 2002 | 07:36 PM
Jack71's Avatar
Jack71
Default Re: What is this thing? (lbell101)
Horn Relay? Thanks guys.
I wonder how it got here. I need an electrical routing diagram, schematics are ok, but man, I just need to know where things are supposed to be.
There's all kinds of electrical horrors under this hood.
Old Sep 20, 2002 | 09:12 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Check your assembly manual. You should find the correct position for the horn relay. I've seen some mount using a bolt, while others mount on a stud which protrudes out of the upper drivers side fenderwell I think that your horn relay also "doubles" as your key buzzer. It does in earlier sharks. Chuck
To What is this thing?
