Seatbelts not catching
Old Jan 2, 2017 | 08:01 AM
snowjoggs's Avatar
snowjoggs
1st Gear
Default Seatbelts not catching
Hi
I recently noticed when yanking my 79 C3 seatbelts they do not catch.
I yanked them really hard and would expect them to stop short like any seatbelt, but they just give. Its like this on both sides.
Im worried what would happend if I were to crash
Luckily its in winter storage now, and hopefully I can fix this before the spring.
Anyone had this issue, what part/s needs replacement?
Old Jan 2, 2017 | 08:19 AM
Big2Bird's Avatar
Big2Bird
Originally Posted by snowjoggs
Hi
I just put new ones in the 81, because they were torn from catching in the jamb for years. You just pull the door pillar moldings and screw the new ones in. I "think" they were $300 a pair.
Old Jan 2, 2017 | 08:49 PM
vettz73's Avatar
vettz73
The seat belt mechanism is designed to lock when the car stops abruptly. You can try pulling on the belt while stopping to see if the inertia mechanism is still functioning properly.
Old Jan 5, 2017 | 10:45 AM
jimvette999's Avatar
jimvette999
As mentioned, the inertia mech seems to be dysfunctional. Sometimes they can be fouled with lint, spider web, mouse nests, rust. I'd remove, clean, lubricate with some PTFE lubricant. Maybe it's only inertia that engages them and not yanking? Yours is similar in form and function to the one below.
More images here >>https://goo.gl/images/kkgRwW
link on forum here>>> https://www.corvetteforum.com/forums...etracting.html
Old Jan 5, 2017 | 11:43 AM
SwampeastMike's Avatar
SwampeastMike
Merely yanking won't cause an intertial belt to lock. Brake hard (in a safe place of course) while you lean forward--the belt should be locked.
To Seatbelts not catching
