1970 L46 camshaft replacement
Old Jan 5, 2017 | 01:13 PM
wb003's Avatar
wb003
Default 1970 L46 camshaft replacement
Hello friends.
I am coming to your for input and advice regarding a selection for a replacement camshaft for my stock L46 350/350 with the M21.
She is in great shape, and still a very strong runner.
I recently took her to my mechanic for brake issues, and I also wanted the carburetor completely broken down and cleaned more completely than what I could do in my garage.
In test drives, my mechanic was not satisfied with the performance, and suspects the camshaft may need replacement.
My question is, should I stick with the stock spec, or select a different camshaft for better performance??
Thank you in advance!
Bill
Old Jan 5, 2017 | 01:26 PM
a striper's Avatar
a striper
Having had two 350/350 cars I remember what a nice all around feel that cam has. I would consider similar valve timing but a little more lift. Roller lifters are nice but the cost will pay for a lifetime of good oil that will keep a flat tappet cam alive these days.
Old Jan 5, 2017 | 02:33 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: do you need a camshaft? Your mechanic "suspects", but he/she apparently had also just rebuilt the carburetor. Before looking at a camshaft, you want to eliminate the carb as a source of the problem.
Old Jan 5, 2017 | 02:37 PM
Revi's Avatar
Revi
Agree with above and make sure your timing/advance curve is set up correctly.
Unless you change the intake manifold and heads, a bigger cam really won't be much better than the OEM cam. The intake and heads just don't flow all that well to take advantage of it.
My L-46, original intake manifold, original heads (ported & valve job), Comp Cam xe262h-10, 10.4 c/r, made 341hp/387tq on the engine dyno. Probably little to no difference than if I had used the OEM cam.
Stock L46/82....0.450/0.460...222/222...................114
CC XE262H.......0.462/0.469...218/224....262/270....110
Old Jan 5, 2017 | 02:59 PM
wb003's Avatar
wb003
Hi Mike. Thanks for the response. Yes, following a test run, he noted rough running, and high speed pops from the intake. He also checked and found some reduced valve travel. His preliminary assessment and update to me was worn cam lobe(s). We will look into it more tomorrow, but currently thinking it to be the camshaft.
Bill
Old Jan 5, 2017 | 03:15 PM
wb003's Avatar
wb003
Stock L82....0.450/0.460...222/222...................114
CC XE262H..0.462/0.469...218/224....262/270....110
Hey Revi, thanks for the response. I figured that the restricted flow of the stock setup would my biggest challenge, but wanted to see if anyone had success by changing cams. I will look at some spec comparisons to see if I can find a compelling reason to change.
Thanks,
Bill
Old Jan 5, 2017 | 03:24 PM
Revi's Avatar
Revi
Thanks,
Bill
Yep, there's no magic cam that is going to give you another 50hp. Intake, heads and cam all have to compliment each other.
When I first brought my engine in for rebuild and discussed what I wanted done. I asked what the HP potential was while keeping all of the stock parts? His response, "you won't get more than 350hp with that cast iron intake manifold".
Old Jan 5, 2017 | 03:39 PM
MelWff's Avatar
MelWff
Default Reduced valve travel
Bill
How did he determine there is reduced valve travel? If the travel was reduced to the point of being visual without actually taking measurements the valves would be clicking really loudly. Do you hear the valves clicking?
Old Jan 5, 2017 | 03:42 PM
jb78L-82's Avatar
jb78L-82
Lets start with an obvious question: How many miles on the motor/Camshaft in the car? If there are more than 100,000 miles on the OEM cam, you might want to examine the cam as an issue closely. camshafts back then did not last like today's rollers.
Old Jan 6, 2017 | 05:42 AM
cv67's Avatar
cv67
St. Jude Donor '05
Maybe his claim was legit maybe he wants to sell parts
If hes legit he can show you whats wrong
IF you cant go HR stick an Isky 270 mega in there youll love it in comarison. Smaller in # but sure will put a smile on your face.
The OEM had a lot of hurdles to overcome to even offer a mediocre cam surprised they could offer what they did.
Try one out and see night and day differnence. Sound good driveable kick azz street torque can still use stock converter and dont go bad
Man they need to put me on pay roll as a face man.
Seriously even today love the way those things run.
CHECK PLEASE!
Old Jan 6, 2017 | 07:53 AM
Revi's Avatar
Revi
CHECK PLEASE!
Stock L46/82....0.450/0.460...222/222....................114
Isky 270...........0.465/0.465...221/221....270/270....108
This cam isn't going to be any better than the rest of them. If you dyno'ed each cam in the same engine you'd get results within a couple of percentage points of each other.
FYI - The 70 L-46/M-21 doesn't have a "stock converter" it's a manual transmission.
Old Jan 6, 2017 | 08:24 AM
7t9l82's Avatar
7t9l82
I'm a big fan of the factory Cam, as mentioned it is very drivable it works well everywhere . It was Zora Duntovs favorite street small block cam. I have used that cam many times over the years and the only addition I'd make is a set of 1.6 roller rockers . You would need to make sure your pushrod slots have clearance. Add a set of aftermarket heads and you'd be amazed.same great drivability and a bunch more power.
Old Jan 6, 2017 | 09:20 AM
wb003's Avatar
wb003
My mechanic pulled the intake to get a better look, and informed me of more ware on the cam. I am about to go to his shop and take a look. From there we will try to make a plan forward.
We talked about how there was no noticeable ticking in the valves. It makes a slight ticking at start up, but my dad (long retired Chevy mechanic) told me those engines always had a little piston skirt slap when cold..
Old Jan 6, 2017 | 09:28 AM
7t9l82's Avatar
7t9l82
Your Dad is a Smart guy and 100% correct. Those engines had forged pistons and they did have a bit of slap when they were cold. Sounds to me like you might have the wrong guy working on your car.
Old Jan 6, 2017 | 09:30 AM
wb003's Avatar
wb003
JB, she has 98,500 miles on the odometer. I'm sure there will be a level of ware.
Old Jan 6, 2017 | 09:36 AM
wb003's Avatar
wb003
I am going to the shop in a few hours to take a look. I am sure that there is some level of wear, but I am not yet wanting to do a restoration. It's a beautiful yellow vert, and it is a blast to drive.
I am hoping that this update can be limited to cam and lifters, and not yet involved the heads...I will post an update later today to see what y'all think.
Thanks to all,
Bill
Old Jan 6, 2017 | 09:43 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I'd definitely look at a different cam. A single pattern/wide LSA cam can be improved upon for sure these days. Just depends on what you're looking for in power and driveability. Lots of compromises in that cam and the right one can help stock heads out.
JIM
To 1970 L46 camshaft replacement
Old Jan 6, 2017 | 10:23 AM
Revi's Avatar
Revi
With 98,500 miles a valve job is probably worth some consideration.
Old Jan 6, 2017 | 11:30 AM
wb003's Avatar
wb003
JIM
Jim, the car is an easy driver, and as you know, has OK power and legs for running around, but could use some more low end grunt. Reliability is more important to me with this car.
A 70 vette is not going to impress anyone with today's cars...but damn, it sure makes me look good.
Thanks,
Bill
Old Jan 6, 2017 | 12:41 PM
427Hotrod's Avatar
427Hotrod
A 350/350 can be a heck of a lot of fun. Won't run with the baddest boys out there...but it can be a 12 sec car...or at least deep deep 13's which can surprise a lot of folks.
Is a HR cam feasible in the budget? Can do some neat stuff there!
JIM
