That is the intake valve opening and is perfectly fine. You should notice valves in different states of open and closed depending where in the firing order the motor is at rest with
Thanks, you bring me peace of mind. I thought that it wouldn't be the only one in a different position.
Actually engine does not tick or make any kind of weird noise. I thought for a moment I had a stuck valve out there.
