Another CA emissions question
Old Jan 11, 2017 | 07:49 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by tfuno
Yeah, there is a fair amount to clean up to improve flow. I plan to find a good used set, then port and ceramic coat. I'll post a pic when done.
It will be interesting to see what you come up with. Keep me posted please.
Just remember, they like to crack.
Old Jan 11, 2017 | 07:55 PM
Shark Racer's Avatar
Shark Racer
I really appreciate the pics, Big2Bird.
Which exhaust are you running that's 3" higher? *edit*: Sorry, if you're running stock exhaust manifolds I can see it being higher in the front. Where it crosses under the differential strut rod brackets, though, it's going to get low.
Note that a 700R4 pan would be a little lower than the TKO. I probably have a picture of that somewhere...
Old Jan 11, 2017 | 07:59 PM
Shark Racer
BTW, here's my car, which is lowered front and rear. I did have issues with scraping, but at the rear section. The front has never really been a problem. I raised the rear a little bit at a time to cover it.
Old Jan 11, 2017 | 08:02 PM
Big2Bird's Avatar
Big2Bird
Magnaflow. They used my car for the prototype pattern. I toured the factory with Richard W., got a free rental car for a week, and the system was free for loaning them the car.
They also dynoed the car before and after. Picked up 13 hp over the stock converter and mufflers.
Old Jan 11, 2017 | 08:09 PM
Big2Bird's Avatar
Big2Bird
Here is the car at Magnaflow R&D. The center guy in the second pic. is Richard Waitas. You've seen him on Overhaulin and a few other shows. Sharp as a tack he is.
Old Jan 11, 2017 | 08:10 PM
tfuno's Avatar
tfuno
My long tubes are about four inches of the ground. I would like to drop the front 2". I have 18x8.5 all the way strong with 40 series tires. If I go to a shortie, I can get an extra inch clearance.
It seems mine hangs lower than yours. That just sounds bad. Lol
Old Jan 11, 2017 | 08:12 PM
Big2Bird's Avatar
Big2Bird
Name:  81 results.jpg
13 HP gain at the wheels. What is neat is the a/f mixture at the bottom. Shows how well the ECM carb system works.
tfuno's Avatar
tfuno
Originally Posted by Big2Bird
Attachment 48052956
Attachment 48052957
Very cool.
Old Jan 11, 2017 | 08:16 PM
tfuno's Avatar
tfuno
I live in the wrong part of the state.
Old Jan 11, 2017 | 09:00 PM
Shark Racer
I bet good money your exhaust looks better than mine. Mine's been "touched" by at least 3 different welders and only a few of them are competent. At least my headers are nice.
tfuno - which part of the state are you in?
I'm running 27.1" diameter (roughly) all around as far as tires, it does help a little with clearance and making the fender gap small. If you've gone down to C4 or C5 size tires, that will exacerbate ground clearance and fender gap "issues".
Old Jan 11, 2017 | 09:22 PM
Big2Bird's Avatar
Big2Bird
I like your tires and rims. I have given up on 15" tires. Time to change.
Besides, TT's are 3lb @ lighter.
Old Jan 11, 2017 | 09:26 PM
ddawson's Avatar
ddawson
I know Richard Waitas from my LS1GTO days. He was a wealth of information.
I too can't believe how many shops can't weld. Most look like they just glob it on.
Old Jan 11, 2017 | 10:46 PM
  #33
tfuno's Avatar
tfuno
I'm in a little town called Galt which is 35 miles south of Sac.
Old Jan 11, 2017 | 11:03 PM
  #34
Shark Racer
I have the numbers somewhere, but I'm running 285/40-18s on the back with 18x9.5" TT2s and they come in at near, maybe a couple of pounds heavier than the 15x8s with 255/60-15s.
Old Jan 11, 2017 | 11:14 PM
  #35
tfuno's Avatar
tfuno
I bought the foose nitrous in 18 x 8.5. They now make a 18 x 9.5 which I round have preferred. I wanted a 19 for the rear but they don't make those. 20 is too big for me.
Old Jan 12, 2017 | 09:57 AM
  #36
tfuno's Avatar
tfuno
Default Classy
That's one classy Vette. Well done!
Old Jan 19, 2017 | 10:37 AM
  #37
Big2Bird's Avatar
Big2Bird
Found this factory video the other day of my car:
https://www.youtube.com/watch?v=uM6y...5IG99&index=78
To Another CA emissions question
Old Jan 19, 2017 | 11:15 PM
  #38
tfuno's Avatar
tfuno
How cool to work with Magnaflow. Nice work.
Old Jan 20, 2017 | 02:04 AM
  #39
centuryoldracer's Avatar
centuryoldracer
Thats pretty cool. Believe it or not I have the same deal with Flowmaster in Hayden Idaho. They have used 6 of my cars so far as pattern cars for a new line of stainless systems. Pretty nice stuff, and you can't beat the price! None of mine went on their Dyno though.
Old Jan 21, 2017 | 11:29 AM
  #40
jb78L-82's Avatar
jb78L-82
Dyno with OEM L-82 (before the complete rebuild/upgrade in 2014) with Mcjacks, 2.5 inch duals, Monza Turbos AND weak #6 compression cylinder:
November 2016 with XS Power 1 3/4 inch LT headers:
