400 SBC Queustion
Old Jan 14, 2017 | 02:02 AM
ENGRMAN's Avatar
ENGRMAN
Default 400 SBC Queustion
OK so I want to build a new motor Ive built many SBC chevy motors. I have a 400 block 1972 out of a motorhome Standard bore nice, new pistons and rings 10/10 crank all new gasket oil pump recon stock rods etc I have a brand new set of aluminum heads from Summit. 76 cc I have heard different opinions on steam holes some say are not necessary. Do I need to have heads drilled 1/8 inch at 18 degrees at the right places or no? I have a pretty good drill press but not sure if I could handle it right myself. Thanks.
Old Jan 14, 2017 | 02:28 AM
gkull's Avatar
gkull
Watch some of these videos. I use a world products intake manifold that is tapped for water flow from the back of the block. A good idea for over 400 ci SBC Are your pistons dished at all? Because my 427 and now 434 ci SBC use 64 cc heads to get compression.
https://video.search.yahoo.com/yhs/s...b&action=click
Old Jan 14, 2017 | 02:30 AM
ENGRMAN's Avatar
ENGRMAN
Default 400 sbc
Oh yeah I still need to buy a cam comp ratio 9.5/1 calced hydraulic recomedations Auto 400 Street only hoping for 360 hp? These heads are not AFRs but like the Patriot ones
Don't know rear diff ratio 336? 75 vette
Old Jan 14, 2017 | 02:33 AM
ENGRMAN's Avatar
ENGRMAN
Oh I think maybe less than 76cc maybe 64 Makes a big difference I know
Old Jan 14, 2017 | 02:36 AM
ENGRMAN's Avatar
ENGRMAN
Oh have to chech on oiston non dished with 4 valve reiefs I would think gotta check Too many variables I guess
Old Jan 14, 2017 | 02:39 AM
ENGRMAN's Avatar
ENGRMAN
Gkull you are so cool I was hoping you would reply S0 I must have steam holes?
Old Jan 14, 2017 | 02:45 AM
ENGRMAN's Avatar
ENGRMAN
just checked 64 cc I bought the heads 8 years ago but never built this thing yet
Old Jan 14, 2017 | 02:47 AM
gkull's Avatar
gkull
Steam holes are because of the block siamesed cylinders make sure that yourhead gaskets have the holes
Old Jan 14, 2017 | 02:52 AM
gkull's Avatar
gkull
You need to get an online compression ratio calculator and figure out the dish pistonsrequired with a .o38 compressed head gasket
Old Jan 14, 2017 | 03:01 AM
ENGRMAN's Avatar
ENGRMAN
I watch some video you referred me to Oh **** I have work to do
Old Jan 14, 2017 | 03:05 AM
ENGRMAN's Avatar
ENGRMAN
I used to do engine machining but oh frick so much to do Cam recommendation assuming I get heads in order? Not trying to kill the world but trying to make a nice motor?
Old Jan 14, 2017 | 03:08 AM
ENGRMAN's Avatar
ENGRMAN
FelPro head gaskets and yes they have steam hole I was going to us as template for cutting steam holes Nothing like a a 406 SBC!
Old Jan 14, 2017 | 03:12 AM
ENGRMAN's Avatar
ENGRMAN
Really nice block though All new cam bearings in btw done right
Old Jan 14, 2017 | 08:01 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
On my 406.......I drilled only the exhaust side steam holes for two reasons:
1)Air can actually get trapped in there due to the Siamese wall.....the other side air can just roll up the deck.
2)The exhaust is on that side.....so....hotter.
I also did the Fel Pro recommended block drilling mod between the center exhaust ports......(see pic). I recommend this as well.
I run Dart Aluminum heads.....10.5 to 1 compression and a stock water pump,fan,clutch......it never goes over 185 even in 105 heat.....with a stock Harrison rad.
Jebby
Old Jan 15, 2017 | 05:05 PM
Kacyc3's Avatar
Kacyc3
are the heads alum. or cast iron?
Old Jan 16, 2017 | 11:46 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I would and have drilled the steam holes or should I say a machine shop did. Some of the holes have to be drilled at an angle otherwise you will drill though the waterjacket.
Angled steam holes should be made using a drill press equipped with an adjustable table
Old Jan 26, 2017 | 09:55 PM
ENGRMAN's Avatar
ENGRMAN
I did a test on valves by putting heads on bench an spraying a bunch of WD40 into ports They didn't leak ANY so I guess they are good. Heads are brand new aluminum and say Summit Racing on the ends
Old Jan 27, 2017 | 08:13 AM
L88Plus's Avatar
L88Plus
Have that block checked and sonic tested before you spend anything on it. If it's solid, build away!
Old Jan 27, 2017 | 03:02 PM
ENGRMAN's Avatar
ENGRMAN
My machine shop did that already. It's standard bore and good to go they said.
To 400 SBC Queustion
