Engine install nightmare
Old Jan 23, 2017 | 11:53 AM
gkull's Avatar
gkull
Originally Posted by Oldguard 7
When i removed this engine in the past I dd removed/nstalled engine from the side. I placed jack stands under the frame by the a pillar. I have the trans supported with the car (corvette jack) and a peice of wood. I cannot get the boom perpendicular and close enough without the legs of the hoist hitting the jack under the trans, thus cocking it or hitting the base of the jackstands thus the engine is too far over to the left or right.
could you move the jack stands forward to under the A-arms? or back under the doors
Old Jan 23, 2017 | 11:58 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Any room to move the jack back, you need one more jack to do this. There is not as much weight under the tyranny as one might think.
I used to put the T10's in there buy arm power. I did the same with the TKO 600, lifted it in place with my hands, that was a nasty one wieghing twice what the T10 wieghed.
Old Jan 23, 2017 | 12:18 PM
Oldguard 7's Avatar
Oldguard 7
I have an engine leveler.
Old Jan 23, 2017 | 12:24 PM
Oldguard 7's Avatar
Oldguard 7
[QUOTE=gkull;1593931500]could you move the jack stands forward to under the A-arms?
Tried moving jack stands under A arms first then moved
To frame just under a pillar.
Old Jan 23, 2017 | 01:31 PM
OMF's Avatar
OMF
If the hoist is hitting the jackstands while your getting the engine where it needs to be, then yo need to move the jackstands to another location further back, and one as far forward as can be.
As you can tell by the responses, it has been done before, and you have done it yourself before....it can be done, you can do it!!!
Old Jan 30, 2017 | 09:54 PM
OMF's Avatar
OMF
Well.......how'd you make out, did you get it installed???
Old Feb 2, 2017 | 09:52 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Old Feb 8, 2017 | 07:31 AM
tektrans's Avatar
tektrans
No news is bad news.
Old Feb 8, 2017 | 08:51 AM
gkull's Avatar
gkull
I was doing some body work in this pic...... explain to me why you can't roll in a engine hoist from the side?
Old Feb 8, 2017 | 05:07 PM
tektrans's Avatar
tektrans
Where did ya get the what looks like 10"x10" lumber?
Old Feb 8, 2017 | 08:41 PM
Oldguard 7's Avatar
Oldguard 7
sstocker31, 63mako, tektrans. I got it installed and the damn thing practically fell into place, a few minutes! go figure.
To make it work I placed the jack stands on the sway bar supports and that gave me more than enough room to reposition the hoist without it's legs hitting the jack I had supporting the trans or the jack stands themselves I also bolted the engine leveler chains in the holes on the cylinder heads closest to the intake manifold which allowed the engine to swing back and forth/side to side easier.
Gkull: never said an engine hoist could not be rolled in from the side. BTW in your pic what did you use to get the car that high off the ground? a crane? (lol)
Old Feb 9, 2017 | 03:58 PM
Duntov's Avatar
Duntov
I did the install with transmission from the front. Got a piece of square tubing (7 ft) and have it extending all the way back for extra weight distribution. Also have a couple hundred pounds of extra weight on the rear legs so that it doesn't tip forward.
Old Feb 9, 2017 | 09:02 PM
  #33
OMF's Avatar
OMF
I guess you weren't holding your tounge the right way the first time
Old Feb 14, 2017 | 11:02 AM
  #34
gkull's Avatar
gkull
BRidge construction trim ends. 12x12 and 14x14. 3 ton aluminum floor jack with a 20 inch lift. I lift the whole side of the vette with a few pumps
