Big Block HP ?
Old Jan 22, 2017 | 05:36 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by Tom454
Have any build sheets?
Sadly no.....that was two houses, one apartment and 10 years ago......
Think of a Big M block 4.560x4.250 Lunati Crank, Eagle H-Beams, Wiseco Pistons for 10.5 to one......Dart Pro 1 345 heads,PAC spring, Dart Intake, Crane Golds 1.7, Jomar Girdle, Comp 748/714 solid roller bracket cam, Isky Red Zones, 1050 Dominator by Pro Systems.....
Made 830-840@6700 RPM.....the cam is somewhat of a lazy grind that is easy on parts......it would make about 700-720 foot/lbs. torque across a 3000 RPM spread.....killer engine.....9.800 deck. Cost about 14k in 2007 dollars....
Jebby
Old Jan 22, 2017 | 06:10 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I wonder how much it would cost to buy the parts and assemble that myself? My skils are fine... been there done that.
You probably have all the tools to build an engine, if not the price of the tools and measuring devices would offset any time and energy put in yourself.
You can build your own but you would have to get good deals on good parts.
I spent 15 grand on parts and some minor machine work for my 427ci small block. All good part and I had all the time in the world to put it together. A crate engine is probably put together in a day or so by someone with questionable skills.
I could have bought a crate engine for about the same but the description of some of the parts was sketchy.
If you build it yourself you know all the measurements and clearances, just like blue printing an engine.
Old Jan 22, 2017 | 06:51 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I would like to add that the Engine I posted above is absolutely bulletproof.....will easily handle a 400 shot of NOS or a 100 mile trip....
I always thought building engines with more stroke than this is kinda worthless unless you are class racing.....
Jebby
Old Jan 23, 2017 | 11:55 AM
Tom454's Avatar
Tom454
Jebby
Is that just parts?
Old Jan 23, 2017 | 12:40 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Is that just parts?
That was complete...carb to pan with dyno......
Jebby
Old Jan 23, 2017 | 02:57 PM
Tom454's Avatar
Tom454
Jebby
So.... you paid for assembly?
Old Jan 23, 2017 | 07:30 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I assembled it.......we absorbed the $750 for full assembly.
Once everything is machined it is a simple matter of measuring it up and putting it together.
Jebby
Old Jan 24, 2017 | 11:20 AM
BLUE1972's Avatar
BLUE1972
Originally Posted by jb78L-82
Without an upgraded C3 suspension, I personally think after about 500+Gross HP, the chassis/suspension is just not up to the task straight line performance or more importantly cornering and braking....just me.
Just because after a while only 1 front tire touches the ground . (and the windows don't close......
Old Jan 25, 2017 | 12:31 PM
Tom454's Avatar
Tom454
Old Jan 26, 2017 | 09:15 AM
dmaxx3500's Avatar
dmaxx3500
and you need 800hp on the street?
500+ is a real big number,
new cars with 600+ have ABS,traction controls and a bunch more so they can be driven ,
Old Jan 26, 2017 | 11:41 AM
v2racing's Avatar
v2racing
Need and want are two different things. 1975's 165 horse was enough to move the car along and cruise at highway speeds, but what fun is that?
You don't need computers to drive a car with big power, that takes skill and the use of one's brain. I will admit some people are lacking both though.
Old Jan 26, 2017 | 12:50 PM
76Rat's Avatar
76Rat
Old Jan 26, 2017 | 10:45 PM
  #33
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
:co ol::p arty:
Yes......just for starters!!
JIM
Old Jan 26, 2017 | 11:03 PM
  #34
TimAT's Avatar
TimAT
Originally Posted by 427Hotrod
:co ol::p arty:
JIM
Old Jan 27, 2017 | 09:28 AM
  #35
Tom454's Avatar
Tom454
All... the object is to test my skills (& have fun) building a high HP BB engine. I'm not expecting to be Mario Andretti on the street. I want to build a high torque BB just for fun... no aspirations of taking on the world. I get my kicks in the building part, not the driving part. After I build it, I'll probably drive it to get groceries. RE: the rest of the car (suspension, trans, diff).... that can come next. Baby steps. It looks like the recipe is more cubes, a forged stroker crank, and a static compression ratio at or above 11 : 1. Is there any inherent benefit to a Roller Cam?
Old Jan 27, 2017 | 09:43 AM
  #36
76Rat's Avatar
76Rat
A Is there any inherent benefit to a Roller Cam?
Yes! More potential Horse Power of course
Old Jan 28, 2017 | 01:57 PM
  #37
TimAT's Avatar
TimAT
I'm building a 496, 10.5:1 compression so I can run pump gas, all forged lower end, and a roller top end with aluminum heads. Bulletproof HD stuff. I'm looking at reliability as much as anything. And should have more than enough torque to break everything else.
To Big Block HP ?
Old Jan 29, 2017 | 05:38 AM
  #38
tektrans's Avatar
tektrans
Yes, especially when you are driving to the track.
At least 800!
Old Jan 29, 2017 | 05:40 AM
  #39
tektrans's Avatar
tektrans
All of that still doesn't stop Hellcat owners from running into walls and tree's.
It's all about the driver and his/her brain.
Old Jan 29, 2017 | 01:56 PM
  #40
Rkreigh's Avatar
Rkreigh
Default fun on the street
I've got a nice 10.5 - 1 496 with a mild hydraulic cam that is speced 569 hp and 525 trq Even at that level traction is at a premium
I'm a bit short of $$ right now so $5250 gets the motor, carb to pan, all fresh, never run
good street motor, scat 4.25 crank and rods, forged pistons, square port alum heads (pro comp), roller rockers, holley 850 DP, high flow pump, hydrualic cam.
If you want to turn it up over 600 hp, I have a solid roller that will allow it to rev over 7k and
polished high rise intake, nice stuff!!!
Back to OP,
I've see the stroker short block kits go for around 4-5k unassembled with some nice parts that will make that 800 you need with the right heads
Or I have a nice M3 procharger that will allow you to do it with the little 496 and have a very torquey and under stressed combo.
I've gone turbo LS of late, so I need to clear out the BB stuff
