Jiggle shifter when starting.
Old Jan 25, 2017 | 04:46 PM
c1nicole's Avatar
c1nicole
Default Jiggle shifter when starting.
68' undergoing engine/tranny/exhaust/suspension/brake restoration. She used to start up with no issue. Since all tranny, engine, suspension, battery cable, exhaust work has been done, she will not start unless you push/jiggle the shifter (automatic).
The shop denies it's a result of anything they have done and that it is just another issue we will have to address.
Any input from you guys as to what causes this and why it is only doing this after tear down and rebuild?
Old Jan 25, 2017 | 04:49 PM
TimAT's Avatar
TimAT
Neutral safety switch is either not adjusted correctly or it's going bad.
Old Jan 25, 2017 | 04:59 PM
Peterbuilt's Avatar
Peterbuilt
Could very well be the NNS.
Does your car start in NEUTRAL or do you have to 'jiggle' the shifter there too?
The NSS switch is under the console.
To Jiggle shifter when starting.
