79 Water Temp Sensor
Old Jan 26, 2017 | 03:15 PM
Tibbs's Avatar
Tibbs
Default 79 Water Temp Sensor
I replaced my stock L48 w/a 383, AFR heads. Old water temp sensor and guage worked fine in L48. Had to buy smaller 3/8" sensor for new head. O'reilly BWD brand..installed and no workie??? Called Willvox and was told if new sensor didn't give ANY indication/needle movement, i had bigger issues than sensor. Any ideas?
Old Jan 26, 2017 | 05:01 PM
MelWff's Avatar
MelWff
if you ground the wire attached to the sensor does the gauge move?
did you use any kind of thread sealant on the sensor that would prevent a complete electrical circuit?
why didnt you use an adapter and use the stock sensor?
Old Jan 26, 2017 | 09:03 PM
Tibbs's Avatar
Tibbs
i will try the ground and see if i get guage movement. The sensor actually came w/teflon on the threads. After my initial startup and got no indication, i removed the teflon and used just a smidge of pipe sealant (like rector seal pipe dope). As far as an adapter goes, did not know there was such an animal..where would i find such a part?
Tibbs
Old Jan 27, 2017 | 05:55 AM
SH-60B's Avatar
SH-60B
Tibbs
Plumbing supply would have it, they are standard plumbing threads.
Old Jan 27, 2017 | 09:03 AM
Darinm's Avatar
Darinm
I just finished the same thing on my 1980. L48 gone with new 383. I broke the tab on the stock one so replace it with an O'reilly sensor. Mine came with no thread sealer so i used regular plumbers teflon tape. No problem with readings. I would try what others suggested and ground it, if still nothing it could be a bad sensor.
To 79 Water Temp Sensor
