What should I look for?
Old Feb 4, 2017 | 05:12 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default UPDATE What should I look for? UPDATE!!
My engine seems to be "straining" whenever I go over 75mph (3,000 rpms). Everywhere else that I maintain under 75mph and normal interstate driving (70mph) and it runs smooth and doesn't strain. Even in city traffic, it runs smooth....600 rpms at red lights and in Drive....take offs are smooth....no missing or hesitations. Any suggestions?????
Old Feb 4, 2017 | 05:32 PM
MelWff's Avatar
MelWff
when is the last time you had a general tuneup, plugs, air filter, FUEL filter, adjustment of timing
Old Feb 4, 2017 | 05:55 PM
vetteguy75's Avatar
vetteguy75
It's been about 2 years. GREAT point! Never even crossed my mind!!!! I used to completely tune it up about once every 9 to 10 months....THANKS!!!!
Old Feb 4, 2017 | 07:10 PM
Kirk H's Avatar
Kirk H
I'm curious to know what you mean by "straining." Could you be a little more specific if possible. I think the members might need a little more to go on for more suggestions if the tune-up doesn't take care of the issue.
The car doesn't appear to be stock on the outside... is the engine mostly stock with q-jet?
Old Feb 4, 2017 | 07:38 PM
'75's Avatar
'75
When you have the distributor cap off for the tune up, make sure the rotor will twist and spring back like it should(centrifugal advance).
Old Feb 4, 2017 | 08:25 PM
vetteguy75's Avatar
vetteguy75
The engine is a GM Performance 350/300hp; true duals with Flowmaster 40 Series; MSD HEI; Holley 650 Street Avenger Carb; Holley Street Dominator High Rise Intake;
By "straining" I mean, when I hit 75mph/3,000 RPMs, the engine vibrates a lot and acts like it's not getting enough of either fuel, spark or air. AND when I continue pass that point, the engine vibrates more, and strains to accelerate.
Old Feb 4, 2017 | 11:27 PM
Kirk H's Avatar
Kirk H
I'm just throwing out ideas here, but I'm sure that's what you're looking for...
It helps a lot to know that it is vibrating only at higher rpm's and won't accelerate much past 3000. If all else seems normal, idle, cruise, light acceleration, water temp, etc, you may want to look at:
clogged fuel filter/or really clogged air filter
points need dwell adjusting or replacing if not electronic ignition
timing upset somehow, maybe too far advanced
float going bad, too low
fuel pump diaphragm tear/ check pressure
Bad spark wires, burned by headers? Sometimes, the extra torque and rpm can make a wire move and burn/arc only in that situation
lightly broken valve springs can act up at higher rpm. I've had broken springs behave entirely differently from each other
Let us know more as you troubleshoot and what you find.
Old Feb 5, 2017 | 08:01 PM
vetteguy75's Avatar
vetteguy75
You bet!
Old Feb 5, 2017 | 08:51 PM
GUSTO14's Avatar
GUSTO14
How does it pull above 3,000 rpm's in the lower gears? Is this something that only occurs above 3,000 in hi gear?
GUSTO
Old Feb 5, 2017 | 10:55 PM
vetteguy75's Avatar
vetteguy75
GUSTO
In high gear.
Old Feb 6, 2017 | 11:20 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by vetteguy75
In high gear.
I would focus on some sort of fuel starvation issue.
Good luck... GUSTO
Old Feb 8, 2017 | 09:13 PM
vetteguy75's Avatar
vetteguy75
Default Update!!! Update!! Update!!!
My trusted and loyal mechanic (been working on my Vette for the past 16years) analyzed my situation and found out my water pump is on "life support". When he grabs the fan, he can rock it back and forth about a 1/2 inch. That's what causing my engine "strain" and vibrate at 3,000 rpm and higher! The engine is running perfectly...he pulled 2 spark plugs and they look as if I had fuel injection system and not a carb. So it's the water pump...which will be replaced tomorrow!!
To What should I look for?
