Which cam gear?
Old Feb 8, 2017 | 04:17 AM
Erichevy's Avatar
Erichevy
1st Gear
Default Which cam gear?
I have a comp cams hydrolic roller cam part nr. 01-414-8
I do not know wich kind of distributor gear is comatible with this cam?
(Bronze/composite/melonized)?
Thanks,
Eric.
Old Feb 8, 2017 | 06:49 AM
bashcraft's Avatar
bashcraft
Melonized.
Never use a bronze or composite gear on the street.
Old Feb 8, 2017 | 07:40 AM
GOSFAST's Avatar
GOSFAST
Thanks,
Eric.
Hi Eric, we use a high number of Comp's "-8" cams, they've performed flawlessly on every build.
All their cams ending with that "-8" number, which denotes cast core blanks, takes an OEM distributor gear and an OEM fuel pump pushrod.
Been using this combo for over 25 years now with not a single failure. They are in just about all our 100% stock-appearing builds, retro-roller units.
Thanks, Gary in N.Y.
P.S. The only recommendation Comp makes on the "-8's" if using any HP/HV mechanical fuel pumps is best to go with a "bronzed-tip" fuel pump pushrod.
Old Feb 8, 2017 | 08:56 AM
bashcraft's Avatar
bashcraft
FWIW, the OEM gear is melonized.
Old Feb 8, 2017 | 10:48 AM
Neil B's Avatar
Neil B
Melonized. Use the AC Delco one.
AC Delco Distributor Gears 10456413
Old Feb 8, 2017 | 10:55 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Crane also sells a new Melonized gear.....
Jebby
Old Feb 8, 2017 | 11:37 AM
Neil B's Avatar
Neil B
Jebby
Just make sure it's for a .491" shaft if using a GM distributor. I think the MSD's are .500".
Old Feb 8, 2017 | 01:06 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
This is correct and Crane sells both.
Jebby
Old Feb 8, 2017 | 11:09 PM
cv67's Avatar
cv67
St. Jude Donor '05
lunati everwear
ever see the aftermath of a composiite gear failure not pretty
Old Feb 14, 2017 | 03:23 PM
StraubTech's Avatar
StraubTech
A bronze gear will run on any cam core.
A bronze gear can run for 1000's of miles if it is a good bronze gear. Morel uses Ampco45 material for their bronze gear.
Melonite gears were developed by Morel.
A Melonite gear is safe to run on any type of Cast core or a 2 pc billet core that has the press on or bolt on gear.
Comp/Crane/Lunati all the same owners.
To Which cam gear?
