Headlight Woes
Old Feb 9, 2017 | 12:04 PM
TERRY CLARK's Avatar
TERRY CLARK
Default Headlight Woes
I just replaced everything but the Headlight Switch & Override Switch. Still takes a long time to open, they close very quick. I can pinch the vacuum hose and let go, and they start opening. Any Ideas ?
Thanx
Old Feb 9, 2017 | 12:27 PM
Kacyc3's Avatar
Kacyc3
Thanx
if pinching a hose closed makes them open faster sounds to me like there is a vacuum leak somewhere that hose is connected to.
Old Feb 9, 2017 | 02:21 PM
SwampeastMike's Avatar
SwampeastMike
Did you test ALL of the new parts to ensure they hold vacuum? An amazing number of new vacuum system parts arrive with significant leaks. Did you replace the hoses? If so did they come from one of the vendors or perhaps Doc Rebuild? I found that hoses available from typical parts stores do not seal well. If you did not replace the hoses and even if you tested them for leaks you cannot assume that they are not stretched out and leaking at the ends.
Old Feb 9, 2017 | 03:05 PM
dshawster's Avatar
dshawster
I 2nd the poor quality hoses, I purchased some hoses from one of the big name auto stores and it leaked down right away. I plugged one end of the hoses and used a mity vac on the other end to pull vacuum, it would not hold vacuum for very long at all.
Old Feb 13, 2017 | 01:42 PM
TERRY CLARK
I thought my hoses were ok, I guess not ! I went ahead and replaced all hoses with the kit I had ordered, they are working now. Tried to save a little time..........thanx !
Old Feb 13, 2017 | 02:13 PM
dshawster's Avatar
dshawster
Old Feb 14, 2017 | 05:10 AM
SwampeastMike
That doesn't surprise me in the least! Glad they're working nicely now. Those old hoses may look--and bench test--fine but the leaks at the connections when installed will bite you in the ***!
Think of all of the rest of the vacuum hoses in the car--especially all of those "emissions" hoses... Consider replacing them all! I did just that in my '79 and the improvements in idling, running, starting, economy, and even comfort (the engine was much quieter at highway cruising speed) were astounding.
If you decide to replace the hoses don't forget the fuel EVAP system (good time to replace the charcoal and filter in the canister as well). If you have an automatic don't forget the small section of hose at the transmission feeding the modulator valve. Doc Rebuild sells great hose kits with excellent hook-up diagrams.
To Headlight Woes
