1969 Tri Power Not Working
Old Feb 12, 2017 | 02:33 AM
f1rob's Avatar
f1rob
Default 1969 Tri Power Not Working
Hi Folks:
I recently purchased an all original 69 Tri Power 427-400hp.
The car ran fairly well, and pulled hard through the rpm range, but the carbs leaked fuel, so I had them rebuilt by a local specialty shop that only does carb work.
They machined the sides of the main bodies, and base plates, drilled and installed bushings on the throttle shafts, etc. A lot of work, but they are the original date-coded carbs.
When i installed them on the car, they run well, idle better, and certainly don't leak any more.
The car runs well on the centre carb, but when I do a full throttle run, the engine revs to about 3500-4000 rpm, and then starts to miss, or bog real hard, and won't rev higher.
The guy at the carb shop suggested that the motor may not be making enough vacuum to open the outboard carbs, and that I should take a reading at a higher rpm under full throttle while driving. I have a hard time with this, since it ran "well" before the carb work was done.
The motor has a roller cam with .510 lift, 282 in, 288 exhaust, so a bunch bigger than stock.
At idle, the motor has 14" of vacuum in the manifold, so less than the generally accepted 17-22", but like I said before, it was fine prior to the work being done. The diaghrams for the secondaries sound to be working fine.
As there is no insurance on the car, I have not driven it on the street since buying the vacuum gauge, so will take a full throttle reading at the upper port of the centre carb, when I get a temporary permit.
I do not believe this is anything with ignition - unless there is a ridiculous coincidence.
Any suggestions on what could be causing this bogging/missing problem, since the carbs were re-built?
Cheers,
Rob
Old Feb 12, 2017 | 11:29 AM
3X2's Avatar
3X2
Is the vacuum hose to the secondary carbs hooked to ported vacuum and not manifold vacuum?
Old Feb 12, 2017 | 12:21 PM
f1rob's Avatar
f1rob
Yes. the 2 outboard carbs are connected to the vacuum port that is 2/3 of the way up on the main body of the centre carb.This is the factory location. I am told that there will be a "0" reading at this port until a much higher RPM for a few seconds. Is that correct?
Thanks for your help!
Rob
Old Feb 12, 2017 | 12:35 PM
3X2's Avatar
3X2
You are correct. BTW, nice engine. Looks like mine except I use a 67 manifold.
To 1969 Tri Power Not Working
