Pitman arm bolt size
Old Sep 23, 2002 | 11:23 AM
TTop Tony's Avatar
TTop Tony
Default Pitman arm bolt size
Anybody know what size the huge bolt that holds the pitman arm is? I was going to drop by the hardware store after work to see if I can find a socket to fit it but I forgot it at home. All I know is its bigger then 1 1/4.
Old Sep 23, 2002 | 11:32 AM
FastGlass79-85's Avatar
FastGlass79-85
Default Re: Pitman arm bolt size (TTop Tony)
:yesnod: 1 and 5/16 :yesnod: Atleast that's what it is on my '79. I could only find it in a 3/4" drive, so a had to buy an adapter for the 1/2" drive impact wrench :yesnod: :smash: :smash: Hope this helps :seeya
Old Sep 23, 2002 | 11:38 AM
TTop Tony's Avatar
TTop Tony
Default Re: Pitman arm bolt size (FastGlass79-85)
Thanks that sounds right to me. I seem to be accumulating a lot of one time use tools. :crazy:
Old Sep 23, 2002 | 11:45 AM
FastGlass79-85
Oh it has a use when your done with the pitman arm :D it makes a dandy paper weight for holding down all the reciepts you never want to total up :jester
Old Sep 23, 2002 | 11:48 AM
TTop Tony's Avatar
TTop Tony
You got that right! I put all my receipts in a folder and I've been way too scared to even look through them. Its a thick folder now too.
To Pitman arm bolt size
