Floor pans?????
Old Sep 23, 2002 | 11:54 AM
honaker's Avatar
honaker
Default Floor pans?????
I pulled the interior and dash to rewire the car. Found a complete shot floor pan sheet metal with some very VERY bubba like repairs. Bottom line is that both side need replaced.
Does anybody know anyone that sells them. I need one for a 77'. I have the equipment and expertise to build one from scratch, however, i could save sometime by buying one if they don't cost an arm and a leg.
Old Sep 23, 2002 | 01:26 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: Floor pans????? (honaker)
Bair's Corvette Parts in Linesville,PA currently sells '76-'82 metal replacement floor pans. I don't know their exact price, but I believe they are over $200 per side. I think they are at http://www.bairs.com
Old Sep 23, 2002 | 02:23 PM
NHvette's Avatar
NHvette
Default Re: Floor pans????? (Paul Borowski)
$265 each in the Volunteer Vette catalog.
Strange - they list 75-77.
:seeya
Old Sep 23, 2002 | 02:50 PM
honaker's Avatar
honaker
Default Re: Floor pans????? (Daves_rusty_75)
Bairs is $249.00 and volenteers was $265.00. I think that's a little spend for a piece of stamped steel.
Sheet metal is inexpensive and my labor time is cheap. I was hoping for something in the $150.00 or less.
Guess i'll mak'em myself.
Dave, I want your floor pans!!! Mine look like the frame rot pic you have on your web site.
Old Sep 24, 2002 | 12:38 PM
glen242's Avatar
glen242
Did mine myself. The only parts that were bad on mine was the foot wells. Using a small brake I was able to fab the sheet metal to go up under the dash, up the sides of the tunnel, and up over and under where the seats mount. Spot welded the patches in place and then covered everything with 2 layers of 'glass mesh cloth.
BTW, liberally coated the sheet metal with Rust-O-Leum (sp).
Old Sep 24, 2002 | 02:04 PM
honaker's Avatar
honaker
Default Re: Floor pans????? (glen242)
I plan on taking out the rivet on the fire wall and undoing all the spot welds and dropping the entire pan. I have access to a pretty well equiped sheet metal shop and their employees. We are going to make one whole unit as a replacement. I think i'm going with a little heavery gauge metal though. More support strengh plus the little bit of weight that it will add will actually be good weight considering the location. Near the rear wheels and low to the ground.
I'm going with galvinized metal, then i'm going to rubber coat the out side and rustulem the hell out of the inside.
Anything i should look out for before i start this project anyone. Never done this before. Would appreciate any words of wisdom.
Old Sep 24, 2002 | 02:20 PM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
i would use POR 15 on the inside of the pans, i think it protects better than rust-oleum. i have been very disapointed with rustoleum paints. i painted the rear impact bar with it and it turned out blotchey and nasty lookin...somebody recommended krylon and i re-sprayed it with that. looks much better.
'74 L-48 4 speed
Old Sep 26, 2002 | 04:13 PM
honaker's Avatar
honaker
Default Re: Floor pans????? (eleven79)
ttt
Old Sep 26, 2002 | 06:26 PM
verskel's Avatar
verskel
I pulled the interior and dash to rewire the car. Found a complete shot floor pan sheet metal ......
Sheet metal ??? :confused:
My '68 floor pans are fiberglass, if I'm not mistaken or is that another '68 thing ? :eek: :crazy:
Old Sep 26, 2002 | 06:48 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Default Re: Floor pans????? (verskel)
My '68 floor pans are fiberglass, if I'm not mistaken or is that another '68 thing?
Gotta love those '68's
:yesnod:
To Floor pans?????
