C3 expansion valve
Old Feb 17, 2017 | 03:28 PM
Duntov's Avatar
Duntov
Default C3 expansion valve
I have the original expansion valve and would like to use it again. Is there a way to test it to verify that operating correctly off the car? I know they can be "rebuilt" but would like to see what I can do myself.
Old Feb 18, 2017 | 12:49 PM
mikem350's Avatar
mikem350
Well no body answered so here goes...see if it holds a vacuum. Not sure how to check the temp sensing/press regulation.
Give it a good cleaning/inspection and try it. If you are in this far I would convert to R134, cheaper in long run.
Old Feb 18, 2017 | 06:25 PM
Duntov's Avatar
Duntov
It will be a 134a system, it will be stock appearing.
Old Feb 18, 2017 | 11:12 PM
dugsgms74's Avatar
dugsgms74
Valve is a pretty simple device, its function is to close off the flow of refrigerant when the evaporator get too cold to prevent it from freezing over. When the sensing bulb sees a too low temperature it shuts the valve.
Couple of quick tests. See if you can blow through it with the sensing bulb at room temp, you should be able to. Second is to cool the sensing bulb, it should mostly, if not completely close the valve. I've used a can of refrigerant in the past to cool the bulb but thats a no-no nowadays, Never tried but a freezer may do the trick.
Old Feb 19, 2017 | 04:42 PM
mikem350's Avatar
mikem350
Originally Posted by dugsgms74
I've used a can of refrigerant in the past to cool the bulb but....
try aerosol brake cleaner
To C3 expansion valve
