Type 2 PS Pump Groan with Borgeson Steering Box
You may note some reservoirs have a fine mesh screen inside. The screen is really not to filter metallic or other particles. The return flow is directed toward the screen and allows fine air bubbles to gather on the screen and rise to the surface of the oil in the reservoir.
I just don't think that aftermarket reservoir suppliers understand the "calming" aspect of power steering reservoir design.
I must add that I have been away for many years from actually inspecting aftermarket reservoirs. So the above are just some of my thinking with respect to the effort that Saginaw (Nexteer) engineers went through when designing reservoirs.
Jim
Jim
This is the new return fitting I made to raise the fluid returning away from the fluid going to the pump. .
Then I placed a fine SS mesh over the return fitting to help with the turbulence in the reservoir. The tie wraps were temp, I replaced them with SS wire. The SS mesh is just tall enough that the lid once installed holds the mesh in place
This is the new fitting installed without the mesh;
The fitting on the side is the Hydra-boost return;
I installed a separate return fitting for my Hydra-boost located above the fluid level to try and reduce the fluid churn. To my surprise there is very little fluid returning from the Hydra-boost.
Neal
Neal
Neal
I came to the conclusion that the fluid temp was not the culprit for the groaning because the fluid was simply not hot enough. However, I felt the temps were too high for a no load test (especially since I will be tracking the car). So, I went ahead and bought a cooler. I went with a 13x5" stacked plate style cooler and made a bracket out of 3/16" 6061 aluminum.
I used the nylon braided hose with AN hose fittings for the low pressure cooler lines. I love the nylon hose. It is so easy to use and doesn't mar up paint like the stainless braided hose. Here is the final config with the Chase Bays baffled reservoir.
Since I didn't think the temps were causing the groan, I swapped fluids from the Royal Purple synthetic to good old GM power steering fluid. I ran the same test again and the peak temp was only 118 degrees. That's a 50 degree difference with no load on the system! The pump is now also whisper quiet.
