Tunnel ram tuning a c3 for 5000ft
2nd Gear
I just bought my first c3 at sea level but I live at 5000+ feet I have a big block 454 and two holley 600 double pumpers on a tunnel ram. Do I just need to mess with the just bring them 3 sizes down and mess with the idle mix screws or is there more?
I live at 5000 also and I had a tunnel rammed street rod. Yes 2 3 jet sizes and bump up the timing the same amount and readjust the idle mixture to get the best vacuum
Received 3,043 Likes
St. Jude Donor '05
If you want to go a step further and can spare 200 bux call Summit and get thier AEM 02 sensor kit you can really tell more via gauge unles you got a good feel for things.
I have a zeitronix o2 data logger for each bank of cylinders. 2-4-6-8 and 1-3-5-7.
http://www.zeitronix.com/
This recorded afr in the 10 range for WOT.
I ended up at 69-74 with a 8.5 power valve.
AFR now in the 12.5 - 13.3 range with a 13.18 1/4 mile times @ 108.2 MPH
I see you have 2 options.
1. get a AFR tool / kit to get it dialed in correctly
2. go to the track to maximize MPH at the end of 1/4 mile. trail and error method.
but at 5000ft you will need to decrease jets sizes and play with timing.
I also have a programmable MSD unit to make any timing curve, which was very helpful at the track. It takes 2 minutes to make adjustments and take another run.
Here is a example from the data logger.
I am logging AFR / RPM / Vacuum / Sensor voltages etc.
