Anyone with experience using 4 pattern cams
I've added R & P, Baer brakes, Electronic ignition, and right now EFI, but I want to update the cam.
I currently have a ZL1 cam, 580-600" lift in the motor (427 + 060, Winters 074 heads, roller rockers, with 11:1 CR) . Not the best low RPM Cam. I have another hydraulic roller, with 595/595 lift.
I am considering one of the new Comp Cams 4 profile cams 11-615-44. It's lift is (about) 660 on the intake and 650 on the exhaust. These have higher lift on the longer runners, and this technology is used by NASCAR engine builders to squeeze another 20 or so HP out of their motors.
The cam itself sells for about $700, so it is not a trivial decision or purchase.
Does anyone have any real time experience with one of these cams? If so, do you have any quantifiable improvements? Or, will I just be spending $700 that I could better spend somewhere else?
Doug in the Frozen Northland of CT
higher lift on longer runners sounds logical but WTF do I know?? my stuff all came from Harold at Ultradyne but not for 10 years, both Ultradyne and camshaft guru Harold Brookshire are long gone, I would ask at the speed talk website
I personally use a .685/714 billet steel with the 4/7 firing order swap on my 434 ci
Imo it's cheaper to buy a few higher ratio rrs and look into staggered jetting
What benefit do you see with the 4/7 switch?
How much did you have to notch your pistons with that big 714 lift on your exhaust?
Thanks.
Doug
On the $700 save your money
What are you expecting from this motor in terms of power, use etc?
Wasnt it Sig Erson that was pushing these back in the 70s (someone help me out here)
You can read up on the altered firing or cam and you will hear less torsional vibration and some minor power gain
I have wisco tiny weight pistons for longer rods. Out of the box they are made for. .800+ lifts. Even with big duration cams
