L36 rebuild - need recommendations
Old Mar 5, 2017 | 04:25 PM
Günther-C3's Avatar
Günther-C3
Default L36 rebuild - need recommendations
Hey!
I want to rebuild my L36 and need some recommendations what mods I should do for more power.
I have to say, I want to keep the already bought new cam (Xtreme Energy XE268H) and the stock iron heads.
Maybe I have to bore the block 0,03" and need some new pistons.
What mods are to do for more power???
Regards, Günther
Old Mar 5, 2017 | 07:20 PM
ddawson's Avatar
ddawson
Build a 496 with iron heads. Really is just depends on how far you want to go.
Old Mar 5, 2017 | 07:45 PM
cv67's Avatar
cv67
St. Jude Donor '05
Due to location guessing youre trying to make the most with what you have?
Compression, little head work a good used dual plane intake, headers usual stuff. Shouldnt cost a bunch
Wont be a high rpm motor but will make good torque with great road manners.
Old Mar 5, 2017 | 08:07 PM
BLUE1972's Avatar
BLUE1972
If you can score a 383 crank / kit - that is the most bang for the buck.
Old Mar 5, 2017 | 09:46 PM
v2racing's Avatar
v2racing
L36 is a 427.
As said, intake headers, cam you have and a good performance valve job will wake it up.
Mike
Old Mar 6, 2017 | 10:00 AM
BLUE1972's Avatar
BLUE1972
Long cold day, should have saw that.
thanks
Old Mar 6, 2017 | 02:30 PM
Danish Shark's Avatar
Danish Shark
Originally Posted by Günther-C3
Hey!
Regards, Günther
Have you verified that the heads are OK? If you have to do any serious work like replacing seats then the price difference to a new set is marginal.
Old Mar 6, 2017 | 05:09 PM
Günther-C3's Avatar
Günther-C3
I will check the heads.
To build a 496 was also my first thought. But does it make sense to build a 496 with stock heads, stock carb (750 cfm Quadrajet), the XE286H cam and stock mainfold??? And a bigger oil pan is also needed, is this correct?
Regards, Günther
Old Mar 6, 2017 | 05:17 PM
hugie82's Avatar
hugie82
The 427 with that cam makes a great street car. If I had to make 1 change , it would be a nice set of aluminum head. Choose a chamber (for a 10:1 comp) and port (square or oval)to match your engine. Then enjoy!
Old May 28, 2020 | 04:39 PM
Mongo!'s Avatar
Mongo!
Agreed on the heads! Before you dump a ton of machine work into them, look at the price of new heads. Had I known how much money I was going to have tied up in machine work, I would have looked around at the "new" prices. Right after I wrote a $2000 plus check for work and parts for my block and heads, I found a local dude on CraigsList that was selling new GM vortec crate motors (with all the covers) for $1500 each. Had I found that first I would have saved at least $1000 and two months of build time....
Old May 28, 2020 | 10:35 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
A good set of AFR heads will gain you like 60+HP with the same cam.And save 80 lbs of weight on the front end.
OTOH a stroker crank will net you you 50ft lbs of TQ on the low end.
Both big dollar moves though.
To L36 rebuild - need recommendations
