Rear wheel studs
Old Mar 9, 2017 | 07:16 PM
antoniov1's Avatar
antoniov1
Default Rear wheel studs
To remove the wheel studs on my 82 on the rear end is it as simple as removing those 4 bolts from the shaft? I don't want to drill
Holes as I've seen mentioned
Old Mar 9, 2017 | 08:27 PM
twinpack's Avatar
twinpack
I'm pretty sure you would have to remove the spindles from the bearing housing so you can press the old out and the new in.
Old Mar 9, 2017 | 08:43 PM
Cool95vette's Avatar
Cool95vette
When I needed to put longer studs in, I cut a notch in the dust shields where I could get the old studs out and put new ones in. I just rotated the hub to line up the stud I was replacing with the notch.
Old Mar 9, 2017 | 10:14 PM
antoniov1's Avatar
antoniov1
Do you happen to have a picture of it?
Old Mar 11, 2017 | 08:20 AM
Cool95vette
I don't have any pics. I cut the notches about at the 5 or 7 o'clock position depending on the side of the car. After I took the rotors off, I just looked where there was the most space behind the backing dust shield and cut a notch wide enough for the stud to fit through. I then tapped the old one out and pulled the new one through with a lug nut.
Old Mar 11, 2017 | 09:19 PM
antoniov1's Avatar
antoniov1
Well I was trying to go around from cutting up the dust shield. But looks like I got no choice lol. What did you use to cut a notch? I tried a drill but can't get a good angle to start the hole. Any advice?
Old Mar 11, 2017 | 09:33 PM
GUSTO14's Avatar
GUSTO14
I've never done this with the spindle assembled.
If you remove an old stud, will that give you a better angle to drill a hole? If it will, just cut half the old stud off and then punch the remainder of it out. Once you have the hole in the shield you should be able to just knock the remainder of them out through the hole and reinstall new ones through it as well.
As for putting a hole in the shield, just use a rubber body plug to cover the hole and it will look like the factory did it for you.
Good luck... GUSTO
Old Mar 11, 2017 | 09:38 PM
antoniov1's Avatar
antoniov1
Ok sweet gonna give it a try tomorrow or later this week.
Old Mar 11, 2017 | 09:49 PM
Cool95vette
I used an air saw like this one.
Old Mar 12, 2017 | 07:11 PM
antoniov1's Avatar
antoniov1
Thanks! Just picked up the electric version at harbor feight
To Rear wheel studs
