Could someone using Trick Flow 23 degree heads with angled plugs tell me which direction the spark plugs are angled at. I want to use these heads on a 67 vet with ramshorn manifolds and want to know if the plugs would hit the center dump or are the plugs angled the other direction away from the exhaust manifold.
I know headers would be better but my primary purpose for using these heads is heat dissipation to avoid preignition and stock appearance is important
Thought I would ask here since more C3 Vets are upgraded with aluminum heads than the older cars. Thanks
Bob
