7,000 rpm sbc?
Assume all out power is NOT a concern.
If someone wanted to build a SBC that'll rev to 7,000 rpm just for the sake of doing it would it take?
Build an LT1 clone? Is the LT1 capable of 7,000 rpm (I know it redlines at 6,500).
Can you get to 7,000 rpm with hydraulic lifters?
What's the most mild cam that'll get to 7,000?
Then a valve train to handle the RPM. Good strong valve springs to avoid float, maybe some behives. Set them up closer to coil bind to control harmonics. Solid roller lifters and a cam with pretty good duration so the springs could keep up.
Then at least 7/8" rocker studs or maybe even a stud girdle to keep flex down to a minimum. And of course full roller rockers.
Good brand, light harmonic balancer.Light flywheel if applicapble, or small diameter (9.0" 9.5") torque converter.
I suppose it depends on how often and how long you plan on getting it to 7000 RPM as well.
The racing world has been doing high RPM engines for a long time. The biggest problem with high revs is component wear and the chance that every rev could be the last.
Jerry
I don't think a hydraulic cam will cut it. And you need a scattershield just in case.
Good luck and have fun. A small block Chevy sounds GREAT at those rpm's.
I used a crane h-flat lifter cam h278-2 with 1.6 rockers. I used good heads, 1.46 diameter valve springs with chromemoly 10 degree retainers. I disagree with running a spring near coil bind you run dual quality springs with 125. Seat # and mid 300open
Sfi damper sfi flex plate single plane 1 3/4 headers true duals with h pipe highly model th350. 3.55 gears and you end up with a consistent mid 12 second bracket car
Also side pipes are not tuned length headers. So they are a power loss compared to quality long tube merge collectors headers
Back in the late sixties my buddies and myself built 283's bored out to 292 with the 30-30 375 Horse/Z28 cam in them. They would spin to 7000 RPM. No roller anything, stock rockers. We used stock 283 rods and never had one blow up. Of course almost 50 years later, those same rods wouldn't be as trustworthy.
Mike
I managed to run it through the quarter in mid 12's a few times, but I never had a chance to really sort it, so I have no idea what it could have done. Shortly after getting it together I was drafted and put the car in storage for 36 years. I shifted it at 7,000 most of the time, and it was still pulling hard, but I did not want to break anything - at least not yet.
I did manage to put a couple hundred miles on it, on the street as well. Traction was the limiting factor on the street and the strip. My class (FX) was limited to a 7" slick. By that time (1970-1971) FX was where they put "modified" cars that were not eligible for Stock or Super Stock, but also not eligible for Modified or Gas class.
These pictures were taken during teardown, after removing the car from storage for restoration.
GUSTO
GUSTO
Mike
gustosure would be fun to pop the hood and see that just the way it is not cleaned up, nothin
OP parts are all over to get them to make power up to not just rev there my 383 blows past 7k like nothing lightweight either
Modern cyl heads, affordable crank kits make getting power within reach these days
Forget hydraulics btw
The #1 limiting factor in a 7000 rpm small block is the size of the oil passages in the block. Even a Bow Tie block needs to be drilled to allow the volume of oil it requires to run 7 G reliably.
A Dart or Motown block eliminates this.......so in my eyes.....I would start with that foundation and just build around it.
More RPM than that requires a lot of changes......drainback being a huge one as well as oil control......
I was around a few Pro Stock truck 358 inch engines and they would repeatedly bump 10,000 on the dyno for 900 horsepower or better......nothing that sounds quite like that.....but it also cost about 50k to build one.
So to cap off....a premium block, a well crafted oil pan with windage tray, and premium valve springs will get you to 7000 reliably all day long.
Jebby
Based on what Comp Cams told me, the engine should be producing about the same horsepower as it did back in '71, but the lack of headers will cost me.
GUSTO
GUSTO
I was wondering why you went to 372 ci
I realize you have a longer stroke but here's a shot below of a 302" pump-gas, solid flat-tappet unit off the dyno at 7000+. Never skipped a beat?
I would add it made no power either, customer had been warned beforehand about using the "smog" heads he supplied. Other than the heads there was all good parts in play. It was a 6.250" long-rod build, low compression. We figure it was about 80/100 HP "light" with the heads.
We have another hyd flat-tappet going on now which will need to reach near 7500, all with a single 1.250" diameter spring (under .500" lift). This has the "R" hyd tappets (mentioned below here) incorporated.
Thanks, Gary in N.Y.
P.S. To reach that 7000 RPM area with a hyd flat-tappet would require some "R" tappets in place of the more conventional hyd ones.
Dont understand this
Why spend all the money for it knowing it will be a slug what was his reasoning someon on the internet told him
Cant help but wonder what he thinks knowing if he stands on a great sounding motor that camry next to him with kiddos in the back would smoke him.
I did it with a relatively mild H Crane cam H278-2 and crane lifters https://www.summitracing.com/parts/crn-99377-16 with 1.6 rockers which gets the valves into the low .500 lift area.
the key is big enough flow through the entire system. 750 cfm carb, single plane (team G) 1/2 inch wood 4 hole spacer. 200 cc heads with 2.055 intake valves 1 3/4 hooker sc headers and free flowing exhaust.
They the key is NO VALVE FLOAT. When I built this H-rollers were not on the market yet.
