Window Regulator Shaft Play
Old Mar 15, 2017 | 05:44 PM
BarryB72's Avatar
BarryB72
Default Window Regulator Shaft Play
I can "spin" the window crank on the driver door about 5-10 degrees before it engages and moves the window.
Took the handle off and I can slightly spin the regulator shaft by hand.
Took the door panel off so I'm ready to get busy.
Just need to know if I can fix it or if it needs replaced.
Old Mar 16, 2017 | 10:27 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There is a bushing and crank handle shaft kit that might fix the issue for you. But when you take the bushing housing off the regulator you need to look really hard at the U that the crank shaft rides in. These things get worn over the years and the only replacement is a replacement regulator or find someone to build it back up for you.
https://willcoxcorvette.com/window-c...t-manual-68-79
Old Mar 16, 2017 | 02:40 PM
BarryB72's Avatar
BarryB72
So this is the part gets "wallered" out?
Old Mar 16, 2017 | 03:13 PM
0Willcox Corvette
Former Vendor
Well check your pin on the shaft too... check both. You should be able to see wear.. It could be the bushing in the housing too.. just look at all items and see where the slack is..
Also check your regulator gear, see if teeth are worn down or missing.
Willcox
Old Mar 17, 2017 | 04:20 PM
BarryB72's Avatar
BarryB72
Here are the passenger side components. They look good to me but they're also the first ones I've ever looked at.
If I lay a screwdriver sideways in the "crank" area and roll it up and down there is a noticeable amount of travel before it engages.
But if this looks good I'll put this one back together and move on to the driver side.
Old Mar 18, 2017 | 10:32 AM
0Willcox Corvette
Former Vendor
It really doesn't look all that bad to me. The bushing might need to be replaced on the housing, only you'll know that by how much slop is in the shaft and bushing. But if you turn that U place on the regulator and have slop then the issue is inside and a royal pain if you try to fix it..
How do the teeth on the regulator look?
Willcox
Old Mar 18, 2017 | 12:14 PM
BarryB72's Avatar
BarryB72
Teeth look good to me but here's what I'm looking at
And this is the passenger side that didn't have as much play.
Old Mar 18, 2017 | 07:40 PM
62corvette's Avatar
62corvette
I can tell by looking at them that the top one has greater slop. Look at the wear on the teeth. They are much sharper than the other because they are worn.
Old Mar 18, 2017 | 11:12 PM
BarryB72's Avatar
BarryB72
So I had put the regulator and tracks back in, put in my new window, got it lined up, and rolled it up and down a few times to get the grease worked in, and then uh oh, it wouldn't roll down.
It clicked, like a torque wrench, released, and then would go down. It was pretty consistent. Roll it all the way up, start to go down and absolutely freeze, release it, click, it would go down.
Took everything out of the door. Used the sideways screwdriver and after a few times it did same thing.
Haven't taken the driver door apart yet, but I'm buying new regulators, right?
To Window Regulator Shaft Play
