Install HEI in 74 Big Block
Old Mar 19, 2017 | 05:43 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Install HEI in 74 Big Block
It should be simple. Just run a 12 gage wire from the IGN post on the fuse block to the batt plug of the HEI. The HEI unit grounds itself to the block via the tighten down bolt..(?) I thought that was the way to go. ??????? It will not fire until the very last second when I release the switch from start to run. The HEI is not being powered while the starter is engaged.
The tach terminal on HEI is empty since I have a mechanical drive tach. How have I screwed this UP?
Where should I power the HEI from. Easiest route would be the resistor wire(s) (there's TWO) but I've been told the HEI needs the full 12 volts.
Any help here?
Old Mar 19, 2017 | 06:29 PM
TimAT's Avatar
TimAT
The pair of wires that went to the coil- one is the resistor wire and the other goes to the solenoid for 12v when cranking. And you are correct in your thinking. Sort out which one of the two wires goes to the solenoid (some have a yellow cloth-looking insulation) and tie that and the new wire together to the HEI. That will give you power when the key is in the RUN position and when cranking.
TimAT's Avatar
TimAT
And I'd use a 10 ga wire too.
Old Mar 19, 2017 | 06:48 PM
fotyfobravo
Thanks Tim .... literally just did that! It worked just as you say!
I put a nice "plug" end with some heat shrink on the two wires and plugged into the BATT terminal on the HEI. Fired right up.
Old Mar 19, 2017 | 07:54 PM
'75's Avatar
'75
In the fuse box, acc has no power while cranking, Ign does.
Old Mar 19, 2017 | 08:23 PM
fotyfobravo
I will double check but I am almost "positive" I was in the IGN pin on the fuse box. Maybe not. Thanks!
To Install HEI in 74 Big Block
