Stuck hood
Old Mar 20, 2017 | 07:34 PM
cooltx73's Avatar
cooltx73
6th Gear
Default Stuck hood
Hi guys , I have a 1973 that I have had for about a year and a half . So far I have rebuilt the front end and the steering along with new shocks,brakes and tires. I installed my new motor last month and finally got everything hooked up and running good ( I move slow). Yesterday when I put my hood on I thought I had it pretty close but it must be off a little because when it latched the passenger side latch will not release. The driver's side is released but not the passenger side. I've searched the threads and know about the access hole in the back of the hood. I tried that but didn't have no luck so I got a 4 foot piece of 1\8 rod and bent a hook in it so I can reach across from the driver's side and release the latch but it is still hung. I'm out of ideas so I thought I would see if this has happened to anybody else .
Old Mar 20, 2017 | 07:46 PM
Dynra Rockets's Avatar
Dynra Rockets
Sometimes my latch sticks a little. I just give it a Fonzie tap with the meat of my fist and it pops right up. I always say "ayeeeeeee" afterwards
Old Mar 20, 2017 | 07:58 PM
cooltx73's Avatar
cooltx73
6th Gear
Thanks for the reply. I think I'm gonna have to get somebody to pull the latch while I give it the Fonzie tap.
Old Mar 20, 2017 | 08:12 PM
BLUE1972's Avatar
BLUE1972
Remember if the drivers side is open the passenger side latch will not be activated. There is a tab that pushes the latch to open the passenger side. You can manually push the latch on the driver's side hood lock to open the passenger side.
Sometimes the lip on the male end gets stuck on the latch.
Depending on how sloppy the hinges are you may be able to wedge the hood rear wood and it may pop.
If it's a really sunny day you can park the car in the sun and let the hood expand - maybe enough to open.
If the hood is too far rearward push forward on the hood and try to pen it.
The last resort is to grind off the bolts that hold the hinge to the body, a real PIA but doable.
Since the driver's side is open I would try to move the hood while pushing on the latch opening tab.
Old Mar 20, 2017 | 08:47 PM
cooltx73's Avatar
cooltx73
6th Gear
I think you're right about the lip on the male end is hanging. I'll try your suggestions tomorrow. Thanks.
Old Mar 21, 2017 | 01:56 AM
tpfarm's Avatar
tpfarm
Heycooltx73, I had the same problem on my '73 with the passenger side stuck shut. After a couple of days pulling , pushing and jerking I finally went under the front and loosened the bolt ends as they came through. I used a needle nosed pair of vice grips and they were easy enough to turn. after a few turns the hood popped open. Hope this helps.
Old Mar 25, 2017 | 09:33 AM
cooltx73's Avatar
cooltx73
6th Gear
I have an update on my stuck hood. After four days of pushing and pulling and a lot of cussing I wound up cutting the bolts off of the right side hinge and it just popped open like nothing was ever wrong. Thank you to the forum. Now time to move on, being a fairly newb I learned you just don't throw these hoods on and and start adjusting them. You need to be very careful and try to line up your hood as close as possible before you lower it down. Also I'm thinking about running my new bolts from the underside up and welding the nuts on the top side of the bracket. As long as the threads don't go above the nut and interfere with the hinge this should work. Does anybody see a problem with this. My wife said why don't you take it to a corvette specialist, I said this forum has plenty.
Old Mar 25, 2017 | 12:21 PM
fishslayer143's Avatar
fishslayer143
kinda late , but if you do it again, there is a hole in the wiper valley passenger side you can manipulate the release from
Old Mar 26, 2017 | 07:42 PM
BLUE1972's Avatar
BLUE1972
When you go to put the hood back on - put a short section of PVC pipe over the Male and align the hood. Will stop it from locking with the head of the pin under the latch. I cut it about 1/2" longer than the male pin.
There is also a thread where you can make a tool to align the hood.
To Stuck hood
