Mysterious spring came out of my parking brake
I went to engage the parking brake on my C3 today, and as I did, the little square cap at the end of the lever popped out (the button you press to release it). It was dark so I didn't see it happen, but when I turned on the light, I also noticed a spring sitting in my passenger seat.
This appears to have been the spring that forces the tab at the base of the lever against the ratchet teeth to get the lever to lock in place. I can manually move the tab in place to lock the parking brake, and I was able to push the little square button back into the end of the lever, so I can use that to disengage it. But looking around the parking brake assembly, (and looking through the exploded view in the shop manual), I can't seem to find where this spring is supposed to go so I can put it back in place.
Here are some photos:
The spring:
The square button I was able to push back into place:
The ratchet and tab I'm referring to:
Can anybody help point me in the right direction?
The spring:
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The spring:
The spring:
Jeff
