68 427 won't start after winter storage
Old Apr 1, 2017 | 09:00 PM
Jims427400's Avatar
Jims427400
Default 68 427 won't start after winter storage
So I'm trying to start the car for the first time this spring and this is what I got so far..
-I've got fuel
-Backfiring up the tripowers
-thought I fouled the plugs so installed a new set.(no change)
-going to check for moisture in distributor cap next
QUESTION
I'd did a google search and read several articles on spraying WD-40 into the distributor cap to coat the surface.
Has anyone tried this??
Jim
Old Apr 1, 2017 | 09:25 PM
drwet's Avatar
drwet
Can't imagine why WD-40 in the distributor cap would be a good idea. If you think you have an ignition problem, do the usual. Check the cap and rotor and replace if in doubt. Backfiring through the carbs sounds like it might be stuck valves. A compression or leakdown test should tell you if this is the problem. If its a fuel problem, pouring a few ounces of fuel down the throat of the carb will get it to fire and run for a few seconds. If that works, you need to figure out why its not getting fuel.
Old Apr 1, 2017 | 10:51 PM
Knerf's Avatar
Knerf
wd 40 in the cap is to get rid of moisture that may have collected in there.
is it trying to start then backfiring or does nothing but turn over then when you let off the key it backfires then?
Old Apr 2, 2017 | 08:21 AM
Jims427400's Avatar
Jims427400
Knerf
That's exactly what it does. Cranks over fires on couple cylinders then backfires throughout carb when I turn off key.
Old Apr 2, 2017 | 10:06 AM
MelWff's Avatar
MelWff
look down the carburetor throats after it shuts down to see if gas is dripping. It is not unusal for a Holley after sitting all winter to have needles and seats not closing properly. Open the site plugs with the engine off and see if you get lots of gasoline pouring out further indication of a float level issue.
Old Apr 2, 2017 | 12:06 PM
BKbroiler's Avatar
BKbroiler
Does your middle carb have a functioning choke? If not, thats a problem.
Old Apr 2, 2017 | 03:53 PM
Jims427400's Avatar
Jims427400
Opened site plugs and got a very small amount of fuel spilling out. And choke is functioning is it should.
Knerf had a spot on idea. The engine cranks with minimal firing then backfires through the carbs when I turn the car off. Any thoughts on why that happens?
Thanks all..
Old Apr 2, 2017 | 09:39 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
dry out the cap or replace it. It sounds like your arcing in the cap. Yes WD40 and some pentrating oils state that right on the label, for moisture in the cap and such.
Old Apr 3, 2017 | 05:05 PM
Zoix's Avatar
Zoix
Default won't start
Don't ignore the points adjust or replace.
Old Apr 3, 2017 | 06:50 PM
7t9l82's Avatar
7t9l82
Run a point file across the points or fine sand paper
Old Apr 3, 2017 | 07:22 PM
Jims427400's Avatar
Jims427400
Sorry, forgot to mention it has the original TI ignition..Although I hope that hasn't gone bad.
Old Apr 4, 2017 | 02:08 PM
Jims427400's Avatar
Jims427400
Default Update
Wanted to get back to everyone concerning my 68. I figured it had to be something basic that had failed. And it's a first for me.
Bad coil..
Has anyone else had this problem? I removed the one that had been on the car for 5yrs. and put the 35yr old one that came on the car and fired right up. Still has some missing to deal with but can take care of that easy enough.
Thanks all for help,
Jim
-I've got fuel
QUESTION
Jim
Old Apr 4, 2017 | 02:17 PM
Knerf's Avatar
Knerf
glad you tracked it down, there are so many things to look at when that happens.
Old Apr 4, 2017 | 08:26 PM
Rescue Rogers
congrats on figuring it out!!!
Old Apr 4, 2017 | 08:44 PM
Duane4238's Avatar
Duane4238
In the future, if anyone has a moisture problem inside the distributor cap, instead of spraying wd40 or some other oil that you'll later have to clean up, just take a heat gun or hair dryer, open the points adjusting door and direct the warm air into the cap. It will dry out the moisture with no cleanup needed.
Duane
Old Apr 4, 2017 | 11:47 PM
Jims427400's Avatar
Jims427400
Ever since I got caught using a kitchen knife for a screw driver my wife watches me like a fox. That's a great idea though..Thanks
Duane
To 68 427 won't start after winter storage
