Bird is correct. What you can do is advance the base timing. Can't do it nearly as well as if you were doing it with a recurve, but you can wake it up a little. On my 81, I advanced it until I got surging at hiway speed and then backed it off a few degrees.
every car may be a little different.bump it up 2 degreess.drive for a little bit and see how the motor likes it.then try another 2 degrees.you will find the sweet spot .
