700R4 Install ???
I drive mostly on highways with foothill, coastal and mountain roads thrown in for fun.
I'll be stroking my 454 to 496 and I'm still on the fence about swapping out my TH-400 and going with a 700-R4 or 200-4R for the overdrive.
For those who have made this swap, what did you have to cut or modify to swap the TH-400 to either the 700-R4 or the 200-4R?
If you had to modify the trans tunnel, were there any issues using the stock seats or center console pieces?
I know the 200-4R is the easier swap, but I'm having trouble finding one rated for the tq and hp ratings my motor may but putting out.
Thanks, Greg
Thanks, Greg
BTW, the 700r4 I had was rated to 600 horse/lbs. I thought it would hold up.......I was very wrong. And the vender welched on the warranty.
For a BB with 3.36 gears....I'd keep the th400 hands down.
If you do the swap, you'll need a driveshaft, yoke, trans mount, but everything fits with no mods to the tunnel. Then the shifter is up to you. I went with a B&M Megashifter, because it had the option for OD or three speed, just remove a pin.
More research...
shortened drive shaft. Th350 slip yoke. Conversion ujoint to connect driveshaft to trans (th350 ujoint to th40p drive shaft...not needed if you use 4L80) Shifter adapter for where shifter cable attaches to trans (i made one from aluminum sflat stock, i also modded my stock shifter to get first gear...i might need new neutral safety.) . Modify crossmember OR get one from bow tie overdrives, torque converter lockup parts: there are optuons here, but a brake light switch made for cruise control, and vac switch.
on topic of crossmember; if using sidepipes, you can mod stock cross member. ( brake pulley and dremel to mounting holes by elongating them 3/4 inch towards rear. HOWEVER, if using 2 1/2 inch exhaust, its a bear to make bends around trans. I got a crossmember from BTO.
if you get a bto crossmember like i did, and later change to a 4L80 , you need to get another cross member and drive shaft. (For a future upgrade i'm considering the spendy TCI 6x 6 speed, which is a modded 4L80. Others have done 4l80s with no tunnel mods.
good luck, i love this mod.
