Jumping Tach
Old Apr 5, 2017 | 12:30 AM
pleasants9's Avatar
pleasants9
Default Jumping Tach
My Tachometer has started acting up. It typically stays bottomed when I start the car then after 5 minutes of driving it starts to jump around then after 10 minutes of driving one solid acceleration it will start to come alive and register with correct and steady readout. Sometimes still jumping sporadically. Does this mean my instrument is starting to fail? Is this something that can be rebuilt or is my only option to just replace the instrument tach? I have attached a link to the video I took. original setup on 1982 Corvette.
Old Apr 5, 2017 | 08:32 AM
blainelocklair's Avatar
blainelocklair
Good morning!
Just as a heads up, I tried playing the video you posted, but got the following message:
I'm on Mac, but embedded videos usually play fine. Might be something in the embed code that's causing the hiccup.
Also, it's worth posting the year of your Vette. Some have mechanical tachs and some have electronic tachs.
Hope these help!
Blaine
Old Apr 5, 2017 | 11:49 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Blaine... I got the same message.
The symptom described could be something loose in the wiring or one of the clips inside the housing isn't making good contact. It could also be the tach board failing.
I'd check the connection at the distributor then I'd check it at the tach filter. If nothing changes, by-pass the tach filter and see if the problem still exist.
If it goes away, replace the tach filter. If it's still there then I'd go inside the housing and check to make sure the clips are making good contact with the studs on the back of the tach and I'd probably pull the housing to make sure the fingers on the pcb behind the housing are making good contact with the connector. (instructions to remove the housing are posted below).
You'll find all kinds of info on our tech page at this link for your tach. http://repairs.willcoxcorvette.com/?yt=1980&s=tach
1978-1982 Corvette Tachometer Testing, Removal, Board Installation
Here is how you by-pass the tach filter.
Old Apr 5, 2017 | 12:37 PM
pleasants9's Avatar
pleasants9
updated
Old Apr 5, 2017 | 12:38 PM
pleasants9's Avatar
pleasants9
Thanks Willcox!
To Jumping Tach
