Power Steering
Old Apr 10, 2017 | 09:13 AM
joelachette1's Avatar
joelachette1
4th Gear
Default Power Steering
After five months of storage I started my 1970 vette the steering wheel turned to the left very fast after investigating I think it might be a control valve problem how can I find out if it has to be adjusted or replaced
Old Apr 10, 2017 | 11:27 AM
MelWff's Avatar
MelWff
try adjusting it first, if adjustment doesn't work than you have to replace it. You did check the fluid level?
Old Apr 10, 2017 | 11:50 AM
marc9889's Avatar
marc9889
I just replaced my control valve due to a leaking seal (bad, bad leak). CSSB has new (not rebuilt) valves for $212.34 on Ebay. They will also buy your GM core for $60.
To Power Steering
