454 valve covers
Old Apr 11, 2017 | 02:42 PM
See Three's Avatar
See Three
Default 454 valve covers
Has anyone used these on a stock LS5 (1971 if it makes a difference) and did you add a hole for PCV? If so is a baffle needed underneath?
Old Apr 11, 2017 | 04:37 PM
MelWff's Avatar
MelWff
are those Ansen, if so read the details concerning baffles and PCV
http://ansenusa.com/product/bbc-454-polished/
Old Apr 11, 2017 | 04:43 PM
jb78L-82's Avatar
jb78L-82
I went to their website as you suggested and the OP needs to buy the PCV with grommets to fit the hole already in the valve cover...both openings have baffles from the instructions:
Baffles Installed
YES
Breathers Included
Push w/ Grommets (PCV available upon request)
Twist w/ No Grommet (496 and Yenko 427)
Old Apr 12, 2017 | 08:02 AM
See Three's Avatar
See Three
Somebody that I know has a set for sale but when I looked at them they only had the filler cap twist holes and it looked like maybe you were supposed to drill your own PCV holes in the flat spots but there were no baffles on the inside in those locations. My guess was that one twist hole was for the filler cap, the other for a breather and you had to make your own PCV hole.
Old Apr 12, 2017 | 01:58 PM
MelWff's Avatar
MelWff
that's a possibility but cant you find out who manufactured the covers?
Old Apr 12, 2017 | 03:24 PM
See Three's Avatar
See Three
They look identical to these ones but I'll have to check if there is any manufacturer markings. I don't even know for sure if they would clear the alternator.
Old Apr 12, 2017 | 03:27 PM
ddawson's Avatar
ddawson
Do you have a brake booster? That for sure would be a issue.
Old Apr 12, 2017 | 07:04 PM
See Three's Avatar
See Three
Yes but the alternator looked like it was closer, car is not accessible right now.
To 454 valve covers
