Offset Trailing Arms
Old Apr 13, 2017 | 01:22 AM
OldCarBum's Avatar
OldCarBum
Default Offset Trailing Arms
I'm still looking at options for the suspension upgrades for my 73 BB. I'm doing further research regarding rear coilovers so I have the ability to tune in the suspension to my driving habits and set the ride height just where I want it.
I'm wondering why the rear coil over kits I've seen all come with 2" offset trailing arms?
Besides giving the opportunity to run a wider wheel, is there any other purpose?
What other changes does this make to the rear suspension?
Will my 17" X 8" with 4" backspace still work without spacers and will the wheels still be in the stock locations?
What about the OEM half shafts and other rear end parts?
Are there any required modifications to the rear end, chassis or suspension components?
Old Apr 13, 2017 | 10:40 AM
Grumpyoldman's Avatar
Grumpyoldman
the only change with quality offset arms is extra wheel clearance. the rest of the spces stay the same. They include offsets with the coil over because they figure your doing it for better handling and will be thinking about wider tires.
you should be able to use your current wheel/tire combo with no problem.
Old Apr 13, 2017 | 11:24 AM
MelWff's Avatar
MelWff
why do you need the coilovers ? Couldnt you make minor adjustments to the ride height with the spring bolts and use Koni adjustable shocks?
Old Apr 13, 2017 | 12:54 PM
OldCarBum's Avatar
OldCarBum
Like I said in my original post, I'm doing research here, with the manufacturers and checking all my options before I purchase one over the other.
Old Apr 14, 2017 | 11:16 AM
ENCSDOUG's Avatar
ENCSDOUG
I have the coilovers front and rear with the 2" offset TA's. My vette rides a lot better. You can adjust the shock stiffness up or down if you get the double adjusting shocks. It's easy to adjust the height also. I bought my front and rear kits through Vansteel.
Old Apr 14, 2017 | 02:03 PM
OldCarBum's Avatar
OldCarBum
I'm seriously considering this option over the composite mono-leaf spring in the rear. Did you have any issues during the installation or clearance issues with the exhaust?
Old Apr 15, 2017 | 10:59 AM
Patro46's Avatar
Patro46
I went with Vansteel offsets and Sharkbite rear coilovers.<br/>Adjustable ride height, and being able to dial in both compression and rebound?<br/>Yea baby.....
Old Apr 16, 2017 | 12:05 AM
OldCarBum's Avatar
OldCarBum
Thanks guys I do appreciate the feed back. I called Van Steel on Friday and talked with Dan. He answered all my questions regarding both the composite rear spring and coil overs. I decided to go with the coil overs front and rear from Van Steel. The difference in price for the rear was only about $600.00 more for the coil overs. The coil overs for the front were only about $300.00 more. The QA-1 shocks are fully rebuild-able and I don't need to worry about exhaust heat on the composite spring. Then Dan threw in a discount for forum members. Very nice of him to do. Dan was great to deal with, very knowledgeable and helpful. They will have my future business for the remainder of my suspension needs.
Old Apr 16, 2017 | 01:47 AM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Dan is a good guy.
Last year he gave me a great deal on the rear offset TA with both the coil over bracket and the johnnie joint front bushing. I already had the QA1 setup. Took them out of the full set that they were selling at the time.
Just need to find a set of upper front A arms from them for the front coil overs.
Van Steel has always treated me fair .
To Offset Trailing Arms
