Starter problems on a 1981.
Old May 2, 2017 | 09:48 AM
Moser28's Avatar
Moser28
You need to check the harness for the starter. I was having issues with starting and tested the starter and it was fine. That harness may be your culprit. I purchased a new one and all of my issues went away. You have to think about how old that harness is and the amount of heat that it has seen over its lifetime.
Old May 2, 2017 | 02:36 PM
Peterbuilt's Avatar
Peterbuilt
Default Good call Moser28!
Check the top side connections on the 'starter motor extension'.
http://www.parts123.com/corvettecent...50g&ukey=10941
Old May 2, 2017 | 02:38 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by Tangis
I'm in Norway.
I did run it on the bench first, and it seemed to be working fine.
Guess I'll try tapping it with a rubber hammer next, and if that works I guess I'm pulling it apart.
When I get home, I can send you my contact in Finland that is very connected. If that helps you. Let me know. His handle is FinnShark
