Swap : LS engine in C3 questions
Old Apr 15, 2017 | 06:08 PM
Redvette_22's Avatar
Redvette_22
Default Swap : LS engine in C3 questions
Has anybody done a "full" LS swap in a C3? I'd like to know where you got the parts & whether you did a trans swap also. I am torn between doing a 383 or 406 for my 72, but reasonably certain that I'm installing a 700R4 trans in the car with the current SBC engine after my builder gets the final price on the trans. The "wrinkle" to that is if I do an LS swap then I'll most likely go with a 4L60E in stead of a 700R4. The car is currently all stock with a NOM, and if I buy the headers that I planned, and torque converter for the TH400, I may as well consider the same parts for an LS swap. I think the price of an LS swap verses buying all the engine parts for a 383 or 406 (need to add a block to this cost also), and the cost of buying a converter for the 700R4 or 4L60E, while being different, may equal out overall. This is my reasoning of doing either engine/trans swap, which is why I'd like input from those that have already done it, and the problems they may have seen.
Old Apr 15, 2017 | 07:17 PM
Gordonm's Avatar
Gordonm
Some have done this swap for about 1500 and the sky is the limit. I have done this to mine with A T56 from an 06 GTO. There are a lot of little things that nobody talks about or need to be done. It is becoming more of a bolt in as more pieces are becoming available for the swap. It will be easier and cheaper to stay with a Gen1 SB but nothing like the power and torque of the LS motors. As I have always said plan on double the money and time you think it will be and you will be close.
Here is my build.
https://www.corvetteforum.com/forums...o-my-72-a.html
