flat tappet
Old Apr 19, 2017 | 11:52 AM
Capt Ken's Avatar
Capt Ken
Default flat tappet
PO installed a crate '82 350 that originally came from a pick up, added a mildly upgraded cam. Time for an oil change. Are all 82 350's flat tappet? Or is there an easy way to tell?
Thanks as always
Old Apr 19, 2017 | 12:06 PM
MelWff's Avatar
MelWff
yes it is a flat tappet, roller didnt start till Gen II small block 92 (Correction it started in 1987 in Gen I)
Old Apr 19, 2017 | 12:58 PM
Capt Ken's Avatar
Capt Ken
Default Gen II
Thanks! Reading your answer, assume Gen II first rolled out in 1992?
Old Apr 19, 2017 | 03:21 PM
Haggisbash's Avatar
Haggisbash
The upgraded cam could have been a roller one though? No easy way to tell from the outside unless maybe the cam chain cover has been upgraded for adjusting roller cam end float.
Old Apr 19, 2017 | 03:28 PM
mikem350's Avatar
mikem350
I would add rollers began 1987 in cars, 96 in trucks.
Old Apr 19, 2017 | 08:33 PM
sunflower 1972's Avatar
sunflower 1972
If you want to be sure, pop a rocker arm off and pull the push rod out. The roller cam rod is shorter.
Old Apr 20, 2017 | 06:44 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
a stock flat tappet rod is 7.8 inches
Old Apr 20, 2017 | 08:46 AM
sunflower 1972
366277 1010 steel 5/16" 7.824" Flat tappet (1) Heavy-duty heat-treated .075" wall, hardened tip inserts. +.100 long
14044874 1010 steel 5/16" 7.724" Flat tappet (1) Heavy-duty heat-treated .075" wall, hardened tip inserts; standard length
Straight from the Chevrolet Performance Parts catalog.
Old Apr 20, 2017 | 03:19 PM
jim2527's Avatar
jim2527
Just use flat tapet compatible oil and your good to go.
Old Apr 21, 2017 | 10:33 AM
Rescue Rogers
mobil one 15w50 is high in both phospahate and zinc, both are 1300 ppm. Mobil one has a chart on their website and its alot cheaper than the racing oil and easier to find. 5gallon jugs at wallyworld are $25 bucks
Old Apr 21, 2017 | 01:29 PM
sunflower 1972
Living in a part of the country that gets a little cold in spring and fall and at times can get really hot in the summer, I use Castrol Edge 5W50 Full Synthetic Motor Oil. ZDDP of 1250 ppm.
To flat tappet
