77 Wiper /Dimmer Switch
Old Apr 24, 2017 | 04:40 AM
Rotonda's Avatar
Rotonda
Default 77 Wiper /Dimmer Switch
Can the Hi-beam/Low-beam switch from 78 and up be used in a Tilt/Telescope column to replace the original 77 part?
I have installed an 82 pulse wiper system with the control on the console, so I no longer need this function in the turn signal lever. The original 77 part seems to be unavailable.
Old Apr 24, 2017 | 11:58 AM
MelWff's Avatar
MelWff
what part isnt available? see the two links below.
https://willcoxcorvette.com/corvette...wash-dim-77-77
https://willcoxcorvette.com/corvette...ilt-tele-69-79
Old Apr 24, 2017 | 12:32 PM
wendellp601's Avatar
wendellp601
I have a '77 myself and it is my understanding that the pivot is the rare item. The switches appear to be available. I actually have a new turn signal switch that I'm hesitant to install for fear of damaging the pivot.
Old Apr 25, 2017 | 06:02 AM
Rotonda's Avatar
Rotonda
I'm sorry I was less than exact. My question should have been - Is the turn signal/dimmer assembly from a 78 up column compatible with a 77 TT column?
Old Apr 26, 2017 | 01:37 AM
jimbo8125's Avatar
jimbo8125
got this on ebay a couple years ago, needs a little rewiring and drilling out the pivot it works great
1 item sold by micksrummagesale
New 1978-79 Chevette Windshield Wiper Turn Signal Switch w/ Dimmer Pivot 7827386
( 221429602637 )
Add note
ITEM PRICE:
US $60.00
Old Sep 18, 2017 | 02:59 PM
77vettejeff's Avatar
77vettejeff
I'm wrestling this same issue. Had a hard time finding Chevette part but have it on order. Could anyone provide the rewiring details?
thanks.
Old Sep 18, 2017 | 11:38 PM
jimbo8125's Avatar
jimbo8125
it does work it is the same switch. Just trace the wires and match the wire configuration on the old switch. You have to move one wire from the d slot on the connector to the c slot on the connector so two wire are in the c slot. You also have to drill out the casting so the big hole is 11/32 to fit the shoulder bolt. Just finished putting one in my 77 and it works great.
Old Sep 20, 2017 | 08:29 AM
77vettejeff
thanks a bunch! This forum and people like you have been such a great help over the years.
At this point in the disassembly process I've removed the turn signal switch.
Does the casting need to be removed for that drilling operation and to remove the pivot assembly?
To 77 Wiper /Dimmer Switch
