L48 intake issue
The thing is I'm still hungry for more power. I can squeal the tires, which is fun, but Id like a bit more which brings me to wanting to get a new intake. After some research I want an edelbrock performer. I have read so much about that with a performer intake not being able to fit under a stock hood and how it can with a dropped base. I haven't been able to find the stock height for an L48 intake thought and I think this would solve the mystery for me if I have some hard numbers.
Or just some people that have done this same thing before?... Id love some help thanks for everything.
A Performer should fit just fine.
I've also read that the current Perforners are designed to produce low end torque. It's also been said that Edelbrock makes the ZZ4 intake. But, who knows.
I'm sure the difference is minimal, though. There is a dual plane intake shootout that was done by a car magazine a few years ago that compared 20 or so intakes. There are differences between the 3 manifolds, but it wasn't a huge difference.
The ZZ4 can also be had cheap on eBay, much less than I've seen the EGR Performers listed for.
Im going to be putting a Performer EGR on a 75 I'm restoring (engine is being built for max power under 5500rpm), and started a thread with pictures of both intakes for comparison.
It sounds like a standard Performer (or Performer EGR) will be the best fit, though the Performer EPS manifold probably deserves a look if a Quadrajet is not to be used.
Is your car manual or auto? If auto, torque converter and rear gears make a huge difference in low end throttle response, i.e. burning rubber.
I bored it but didn't stroke it, has the original crankshaft. She was just bored to a .030 to make it 383.
So your saying the original Quadra-jet Carb is better then a performer carb?...or is a Q-jet carb something different then the stock one?
I've put over 40,000 miles on Edelbrock carbs on my 79. They'll work just fine (though I am going to try out a Qjet on my 79 to see if I like it better... past experience with a Buick 455 was that the Edelbrock made more power than the Qjet, but that could have been a fluke). Most C3 Corvettes came stock with Quadrajet carbs.
I still have the stock rebuilt Qjet, I got the Edelbrock a while back thinking it would bring some more power...not doing my research I didn't even know still don't know the specs on the Qjet, (CFM ect)
Depending on which carb I use I think will help determine the intake as well, because the 1" conversion plate I have is killing me for space under my hood!!
Every Edelbrock intake that is made to accept a Quadrajet will also accept an Edelbrock carb. The ZZ4 intake will accept both, as well. So, a Performer (with or without EGR), ZZ4 or Performer RPM Qjet will all allow you to use the Qjet or Edelbrock carb without any adapter plates.
I personally would go for the ZZ4 or Performer (EGR) manifolds for hood clearance reasons, and being able to use a heat insulator gasket if needed.
If you can spin the tires, more power is only going to spin them more.
Chsnging your rear gears from 3.08 to 3.55 or similar will help a bit. According to the 79 user manual, automatic L48 cars were supposed to have come from the factory with 3.55 gears. Though, that will mean higher rpms on the highway.
The Q-Jet is an excellent carburetor. It is actually a mechanically secondary carb that has a spring loaded air flap that opens on demand so a well tuned Q-Jet will never be "too much carb" for the engine. Remember, GM used the Carter AFB (which the Edlebrock is based on) back in the '60's. They dumped it for the Q-Jet to get both better performance and better mileage.
