Where did my brake fluid go?
Old Apr 27, 2017 | 07:28 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Where did my brake fluid go?
Willwood master cylinder drained
Booster after removing master cylinder
MC removed
Underside of MC rod
I checked all calipers and didn't notice any fluids. The car has been sitting in garage for about a year and half. I do start it every 4 to 5 months. The willwood MC aND calipers have been on the car about 7 years.
Old Apr 27, 2017 | 07:44 PM
BlackC3vette's Avatar
BlackC3vette
From the photos, it looks like the rear (secondary) seal in the master was leaking.
Old Apr 27, 2017 | 07:56 PM
CanadaGrant's Avatar
CanadaGrant
Since the rod is wet behind and in front of the seal it looks to me that the fluid leaked past not only the master cylinder seal but also the booster seal. I bet your fluid has formed a small lake inside the bottom of your booster.
Old Apr 27, 2017 | 08:16 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
That would be my guess, take out the vacuum grommet and stick a probe down in there, it'll come back wet possibly
Old Apr 27, 2017 | 08:19 PM
sunflower 1972's Avatar
sunflower 1972
Or, it's possible that it went out the tail pipes due to the fluid being sucked into the VACUUM booster.
Old Apr 27, 2017 | 09:25 PM
BlackC3vette
Put a vacuum pump on the booster check valve and pump it to 15 to 20 in. of vacuum. Let it sit for awhile and see if it holds pressure.
Old Apr 28, 2017 | 08:22 AM
mrvette's Avatar
mrvette
In the pix, the M cylinder end piston area looks too clean, like it was new, so I would be examining the brake lines really good, and one of my mystery leaks came down to that silly valve with the wire on it, nothing but an alarm switch that light a lite to tell you one of the brake circuits has no pressure.....woopie doo, as if a driver can't tell that from the feel of the way the car reacts......My brake switch was replaced with a simple splitter block for the front, and the rear line run straight to the m/cylinder....no more mystery fluid loss......I wish I had all that Wilwood brakes set up on my car....love to find a used set for the front....
that is a HINT, anyone......
Old May 9, 2017 | 09:57 PM
74 vert's Avatar
74 vert
Default Back on the road
After some gravity bleeding of four calipers still noticed contamination in rear of mc
Got this from harbor freight. Bled about a quart and achieved peddle!! Runs with compressor to pull fluid through the lines.
Old May 10, 2017 | 10:49 PM
Rescue Rogers
what is it called. I have never seen that before. Very nice and clean
To Where did my brake fluid go?
