c4 stuff into c3
Old May 1, 2017 | 05:32 PM
vetski179's Avatar
vetski179
Default c4 stuff into c3
After 13 hours of grimy, backbreaking work, a guy gave me the entire front cradle (control arms, steering, shocks, etc) and complete rear diff from a c4. A latter c4 with the speed sensors. Unfortunately, my c3 frame is already powder coated and I don't want to re-blast it to get it back to bare frame to weld/cut. Curious what stuff I might use on my 1980 without cutting/welding. I'd hoped to use the plastic spring and would appreciate any other suggestions. Thanks.
Old May 1, 2017 | 05:41 PM
Dynra Rockets's Avatar
Dynra Rockets
With a welder and a sawsall you can do anything but nothing I am aware of will bolt in. Even the spring is different length and width.
the C4 tubular exhaust manifolds will fit an automatic car but no real performance benefit other than dropping a few pounds.
Old May 1, 2017 | 08:44 PM
Gale Banks 80''s Avatar
Gale Banks 80'
There is absolutely nothing interchangeable including the spring.
terry82's Avatar
terry82
sell everything and get what fits.
Old May 1, 2017 | 08:52 PM
ddawson's Avatar
ddawson
Or send your frame out and be converted.
Old May 1, 2017 | 11:32 PM
The13Bats's Avatar
The13Bats
If you track down a c3 called hammerhead, that cat thinks outside the box he used c4 suspension on his wild c3, not bolt in but made it happen
Old May 2, 2017 | 02:10 PM
vetski179's Avatar
vetski179
thanks
Old May 2, 2017 | 06:51 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I understand not wanting to cut up a good looking frame. I bought a spare/used frame and cut that up to install my C4 suspension. Lotta work, but worth the effort to get the suspension under my '69. The C4 suspension looks better, handles better, and is lighter weight.
I prefer the strength/affordability of the stock C3 differential, but I did use the C4 batwing on my stock differential for another 20# reduction.
Old May 2, 2017 | 07:19 PM
Dynra Rockets
Originally Posted by 69427
i prefer the strength/affordability of the stock c3 differential, but i did use the c4 batwing on my stock differential for another 20# reduction.
like!
Old May 3, 2017 | 02:11 PM
ddawson's Avatar
ddawson
I still think this is pretty cool from SRII
Old May 4, 2017 | 01:26 PM
80-Vette's Avatar
80-Vette
I have a very similar set up on my 57 Chevy 150.
To c4 stuff into c3
