Driveshaft ?
May 1, 2017 | 09:28 PM
Driveshaft ?
Looking at driveshafts the 2" is for standard and 2.5 for autos? 1968 to 76 is different then 1971 thru 79
May 2, 2017 | 12:59 AM
I'm a manual but I use a 2.5" from fortwayneclutch.com
May 2, 2017 | 01:46 PM
You changed yokes or use the offset joint?
May 2, 2017 | 01:48 PM
I've also noticed some Vendors don't even list after 1970.
May 2, 2017 | 03:54 PM
Can't recall the size but it matched the trans yoke and rearend. No offset required. Give them a call.
May 2, 2017 | 06:09 PM
So u joint for 75 2.5 shaft auto originally 1330? Or 1310? I asking because sometimes it's really hard to get the caps to seat. Could that be because of the approx 1/2" difference
May 2, 2017 | 07:58 PM
Quote:
Originally Posted by
croaker
If I'm reading my Corvette Parts Book correctly, driveshafts break down as follows.
All 63-67's used the 2" driveshaft. 68 and 69 with manual trans also used the 2" driveshaft.
68-76 with the Turbo 400 used the 2 1/2" driveshaft, and so did 70-79 4 speeds.
May 2, 2017 | 08:38 PM
That's kinda what I'm getting to. Thanks for the replies guys.
May 2, 2017 | 08:42 PM
So second part of question did they come with 1330's or 1310's?
May 3, 2017 | 12:48 PM
2021 C1 of the Year Finalist - Modified
May 3, 2017 | 01:35 PM
