Stuck Lap Belt
Old May 7, 2017 | 07:52 AM
rmgny44's Avatar
rmgny44
Default Stuck Lap Belt
My passenger side lap belt is fully extended and now won't retract! Any tricks to get it to retract?
Old May 7, 2017 | 10:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you cleaned the retractor?
Old Oct 10, 2018 | 11:14 PM
wolvercote's Avatar
wolvercote
My problem is the belts work fine out of the car but won't retract once installed. 1974 roadster with new insulation and carpet and belts restored by snake oyl.
Old Oct 10, 2018 | 11:45 PM
NONN37's Avatar
NONN37
if it works out of the car, maybe they are mounted wrong. im not sure about 74 vettes but the retract lock mechanism is desinged to only work on certain angles. if it is oriented wrong the inner ratchet lock will not engage/disengage properly. good luck
Old Oct 11, 2018 | 09:16 PM
Its_hers's Avatar
Its_hers
I just went through this with my '73. There is a "cam" on the retractor spring that times the free rotation before it ratchets. Off the car mine worked well but that was because the timing had slipped and only allowed it to pull freely when the belt was further in than when installed. It's the orange ring on the spring, so remove the retractor (again), remove the clear spring cover and rotate the orange ring until it works properly. Make sure the ratchet bar can move back and forth easily. Some trial and error will be required.
Old Oct 20, 2018 | 08:28 PM
wolvercote's Avatar
wolvercote
Got it, thank you for reply
Old Oct 20, 2018 | 08:30 PM
wolvercote's Avatar
wolvercote
You are correct.Had to be at correct angle. Thank you for your help.
To Stuck Lap Belt
