Another Timing Question
Old May 7, 2017 | 01:44 PM
blanman61's Avatar
blanman61
Default Another Timing Question
78 l-48 stock. All emissions, vapor canister have been removed, everything plugged on carb. My question is does this have any affect on timing? The book says 6 deg btdc, checked it with dist vac line plugged & it was @ 8deg. Don't think it would make a difference but wanted to hear from the experts, thanks.
Old May 7, 2017 | 01:50 PM
C3 4ME's Avatar
C3 4ME
emissions and vapor canister would have no effect on timing.
Old May 7, 2017 | 03:21 PM
Engage's Avatar
Engage
It has no effect on timing.
You can probably run 12 deg btdc....... you will get a little better throttle response.
Old May 7, 2017 | 04:02 PM
blanman61's Avatar
blanman61
Thanks Engage, will give that a try
To Another Timing Question
