82 won't move in gear
Old May 8, 2017 | 03:43 PM
antoniov1's Avatar
antoniov1
Default 82 won't move in gear
Hey I need some help with this one. Just got done bleeding my brakes in the vette. Was gonna test it up the road. And when I put it in any gear it just feels like it's on neutral. And when I give it gas just revs. I made sure the shifter is moving the linkage and it is. What else should I look at?
Old May 8, 2017 | 03:45 PM
antoniov1's Avatar
antoniov1
IF This helps also put a new key cylinder in.
Old May 8, 2017 | 04:33 PM
MelWff's Avatar
MelWff
did you check the transmission fluid level?
you looked at the linkage on the transmission case and it moves with the shifter?
do you have reverse?
Old May 8, 2017 | 05:18 PM
antoniov1's Avatar
antoniov1
Yes fluid is good. And yes I looked at the shifter linkage on the side when someone shifted it for me and it moves as it should. I don't have no gears. I can't even feel anything engage. It just goes into whatever gear I put it in without any feel of it catching.
Old May 8, 2017 | 07:10 PM
REELAV8R's Avatar
REELAV8R
Check the pivot bolt that the linkage is a attatched to that goes into the transmission. If that nut comes loose then the linkage will still move but will not rotate the rod that goes into the transmission.
The rod will have a flat on it to position the linkage correctly and a nut to hold the linkage in place.
Old May 8, 2017 | 07:53 PM
antoniov1's Avatar
antoniov1
Ok thanks man I'll check it out tomorrow
Old May 9, 2017 | 03:17 PM
antoniov1's Avatar
antoniov1
Nope wasn't it. I'm thinking it's this lol. Do you know what size bolts I need?
Old May 9, 2017 | 03:43 PM
MelWff's Avatar
MelWff
you posted a picture of a flex plate. the flex plate bolts to the crankshaft and torque converter, so which bolts are you talking about and why would all of them neatly fall out without you hearing anything?
Old May 9, 2017 | 03:45 PM
antoniov1's Avatar
antoniov1
This hole circled does bolts go there? Cause it was a project car
Old May 9, 2017 | 03:52 PM
MelWff's Avatar
MelWff
look at the pictures in this link
http://www.chevydiy.com/gm-turbo-350...llation-guide/
Old May 9, 2017 | 04:55 PM
REELAV8R's Avatar
REELAV8R
3/8"-24 bolts and nuts. Grade 8, not typical big box store types.
Here is some listed on Jegs
http://www.jegs.com/i/Spectre/865/46...FQ6LaQod9CABBw
How the heck did they come out and leave so quietly?
Old May 9, 2017 | 05:42 PM
antoniov1's Avatar
antoniov1
I have never driven the car. I bought it as a project. So never knew they was missing. Will I need the nuts too? Or just bolts? Since it's a 700r4
Old May 9, 2017 | 06:15 PM
'75's Avatar
'75
700r4 should use 10mm 1.5 thread bolts.
Old May 9, 2017 | 08:05 PM
REELAV8R's Avatar
REELAV8R
Sorry, though we were dealing with a TH350 here.
https://www.summitracing.com/parts/a...FdO3wAodaF0OVQ
Old May 9, 2017 | 08:11 PM
antoniov1's Avatar
antoniov1
How many would I need?
Old May 9, 2017 | 08:16 PM
'75's Avatar
'75
It takes 3 bolts. there will likely be 6 bolt holes in the flexplate, however it is two sets of 3 , one set will be the right bolt circle and the other set won't line up with the converter holes.
Old May 9, 2017 | 08:19 PM
antoniov1's Avatar
antoniov1
Alright thanks man! I'll let you know how it goes this weekend. Oh yes will I need nuts? And what's the torque on the bolts. And do I need to put any kind of loctite
To 82 won't move in gear
Old May 9, 2017 | 09:17 PM
'75's Avatar
'75
35 to 40 lb ft should do it and blue locktite is good also.
Old May 9, 2017 | 10:38 PM
antoniov1's Avatar
antoniov1
Ok thanks again man. So would I need nuts like sole transmissions call for?
Old May 10, 2017 | 07:54 PM
'75's Avatar
'75
Usually the torque converter holes are threaded, so no nuts.
